Master Cylinder/Booster for non-ABS EK with 5 lug conversion
I did a search for master cylinder and found plenty of prior posts regarding this topic, but replies to whether a certain master cylinders would fit or not seem to be conflicting.
So, for this post, I am interested in hearing replies primarily from those with 96-00 Civics whom have already swapped their master cylinder. Please let me know which master cylinder/booster you replaced your stock one with, and whether it was a direct bolt on or whether you had to ghetto rig anything (flaring, bending, etc.). Be sure to include the model year of the car it came off of and whether the car it came off of had ABS or not.
I am especially interested in getting the ITR Master Cylinder/Booster and heard that they are a direct fit according to this post:
https://honda-tech.com/zerothread?id=170740
But I also heard that ABS Master Cylinders don't fit non ABS cars without modifications, and all ITRs have ABS. So, I am interested in knowing whether ITR master cylinders are indeed a direct fit or not. Also, are JDM and USDM ITR master cylinders the same? If not, how are they different and which one would be a better fit?
Bump. Need to know cause somebody is offering an '99 JDM ITR master cylinder/booster for sale and I need to know if I should buy it or not.
Bump.
Id like info on this as well.
Eric: What year civic are you working with?
[Modified by thinkbrianthink v.1, 1:38 PM 12/19/2002]
AFAIK, the M/C and booster should be fine regardless of ABS. I used 99-00 Civic SiR (Canadian Si) ones with a CTR P/V, and everything bolted up perfectly.
From what i know, you could either go with the EX MC/booster/prop valve (30/30), mc/booster/prop valve (40/40) off of an RS integra, or the setup from a 99-00 Si.
itr or 98+ integra bmc and prob valve from a usdm car are direct bolt on a ek... no bending or mods required... with or w/o abs doesnt matter
How about one from a '99 JDM ITR? Is it any different from the USDM one? The seller says it would fit w/o any flaring. He says it's a direct bolt on. Just want to somebody to confirm this before I buy. Thanks!
Here's my 98 spec JDM ITR BMC (notice the line on the side of the BMC has been modified to fit a JDM BMC):
nope the JDM ITR BMC is direct bolt on but you will have to modify one of your plumbing since the BMC is from a RHD car...
i think the itr and the si prop valves are the same... i have a 00 civic but 96-00 same ****... i would use a itr prop valve since you're doing a 5 lug conversion
Nope. The ITR has ABS and the 99-00 SI doesnt. Since he is swapping this into 96-00 civic which has no abs...he needs the prop valve from the 99-00 si.
i have 00 Si with 5 lug, of course i didnt have toor want to swap booster or anything. i do have a booster adn everything from a 2000 Si if you are interested. email me...
Has anybody successfully used an MC/Booster off of an ABS car on a non-ABS car? Does the MC/Booster have additional lines coming out of it that get routed to the ABS equipment? If so, would it be possible to cap off those lines at the MC to make it "non-ABS"? I have access to a 94-00 GSR MC/Booster (orig ABS equipped) to use on my EG. Can it be done?
You should be more concerned about the P/V than the MC/Booster. I have a 96 CX and used a 99-00 SiR (Canadian spec Si with ABS) MC/Booster with a CTR PV. Everything bolted up perfectly. My friend used an ITR MC/Booster/PV, and he had to reflare the lines to the PV.
heres exactly what you do. Get a 1998-2001 GSR 4 door BMC and booster. Bolts right in, no bending. I have it on a 96 DX with 5 lug. **** brakes on a dime. I also used a 99 SI prop valve. This is all straight forward and very effective!
