What filter are you guys running with 4inch inlets?
Old Dec 17, 2002 | 12:31 PM
bgod's Avatar
Default What filter are you guys running with 4inch inlets?
Just wondering, what filter set-up are you guys running with 4inch t4 compressor inlets. Compressor inlet on the driver side of course.
Looking for some ideas.
Old Dec 17, 2002 | 12:32 PM
ekb18c's Avatar
Default Re: What filter are you guys running with 4inch inlets? (bgod)
hks mushroom! yes they come 4 inchs.
Old Dec 17, 2002 | 12:38 PM
bgod's Avatar
Default Re: What filter are you guys running with 4inch inlets? (ekb18c)
damn, they come in 4inch configurations. wow.
only thing that concerns me is the foam. are there any paper filters like k&n that come in 4inch diameters?
Old Dec 17, 2002 | 12:41 PM
swrdply400mrelay's Avatar
Injen which are also K&N.
http://www.nipponpower.com/airfilter/filter.html
Old Dec 17, 2002 | 01:56 PM
Farnsrocket's Avatar
Default Re: What filter are you guys running with 4inch inlets? (swrdply400mrelay)
This is a K&N. I can get the part # if you want it.
Old Dec 17, 2002 | 01:58 PM
ekb18c's Avatar
Default Re: What filter are you guys running with 4inch inlets? (Farnsrocket)
woah! K&n has a 4 inch filter? Part number please..
Old Dec 17, 2002 | 02:05 PM
Where did you get that flexible piping for your wastegate dump tube? How is it connected to the dumptube?
Old Dec 17, 2002 | 02:08 PM
autoEXturbo's Avatar
That's the one i use.
Old Dec 17, 2002 | 02:12 PM
Default Re: What filter are you guys running with 4inch inlets? (autoEXturbo)
http://www.knfilters.com/universal/univrndtap.htm Here is the K&N site. They have quite a few different 4" filters with varying lengths. I got the dump tube pipe at Napa. It's just 1 1/2" flex exhaust pipe painted high temp gray. The clamp is a 1 5/8" exhaust clamp. You can get the pipe and clamp at Autozone or Napa.
Old Dec 17, 2002 | 02:13 PM
boosted92's Avatar
K&N makes ones in up to 5 inches I think.
Old Dec 17, 2002 | 03:29 PM
98Psi ITR's Avatar
Default Re: What filter are you guys running with 4inch inlets? (boosted92)
AEM makes a 4" filter as well.
Old Dec 17, 2002 | 04:20 PM
boostaholic's Avatar
Default Re: What filter are you guys running with 4inch inlets? (98Psi ITR)
K&N makes several 4" inlet filters with different lengths. I used one with a 3.5" length.
Old Dec 17, 2002 | 06:26 PM
Heath's Avatar
Old Dec 17, 2002 | 06:38 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: What filter are you guys running with 4inch inlets? (95civicturbo)
none, just a screen.
Old Dec 17, 2002 | 06:45 PM
Alstare's Avatar
Default Re: What filter are you guys running with 4inch inlets? (MotorMatrix.com)
is there any benafit to moving the filter away from the engine kinda like a CAI idea? I have seen them setup both ways... filters on the turbo and some piped out of the way... Would it help for getting cooler air? or would it not even matter if your gonna use an intercooler anyway? Thanks
Old Dec 26, 2002 | 12:29 PM
JCushing's Avatar
i have a 4" filter for sale, 10 bux plus shiping.....
https://honda-tech.com/zerothread?id=365698
a1320addict
Jan 15, 2006 01:56 PM
sean
Oct 6, 2005 09:52 PM
DC2_Integra
Dec 11, 2002 04:25 PM
