Turbo Build up Advice Needed. Knock sensor on B20 block ?
Old Dec 17, 2002 | 12:23 PM
chameleon's Avatar
Default Turbo Build up Advice Needed. Knock sensor on B20 block ?
Guys, I hear that B20 blocks dont come with a Knock sensor, i need to know what is the best route to go ? because i hear that B20z blocks that are jdm come with a factory Knock sensor, isnt that sensor needed for proper vtec operation or something? im going with a b16 or b18c head, and the motor will be sleeved for turbo and im using a P28 w/ hondata ..
do i need the sensor or not ? already know the P28 wont read it but what do you guys suggest ?
Old Dec 17, 2002 | 12:29 PM
ekb18c's Avatar
Default Re: Turbo Build up Advice Needed. Knock sensor on B20 block ? (chameleon)
if your runnign the p28 which doesn't read the knock sensor, then you dont need the knock sensor on the block.
Knock sensor will not affect vtec.
I acutally like to disengage the knock sensor sometimes on turbo cars. It's more of pain in the **** then helpfull.
Old Dec 17, 2002 | 12:45 PM
chameleon's Avatar
Default Re: Turbo Build up Advice Needed. Knock sensor on B20 block ? (ekb18c)
does it help in motor longetivy? thats basically what im converned about, if it helps in some certain way then i would feel better having it.
Old Dec 17, 2002 | 12:50 PM
ekb18c's Avatar
Nope!
Besides your getting it tuned via hondata so your all good.
Old Dec 17, 2002 | 01:01 PM
chameleon's Avatar
Nope!
thanks, i feel so much better
philcivicjordan
Oct 19, 2015 12:30 PM
1sikhatch
Aug 17, 2010 08:20 AM
efstile
Jul 31, 2005 08:55 AM
Se-rv-Tak
Dec 2, 2003 09:04 PM
MrFatBooty
Dec 12, 2001 10:11 AM
