rear brake problems
I put 90-93 integra rear brakes on my 91 hatch and I have really bad caster, I got
a 4 wheel alignment but it hasn't gotten much better. Any info would be appreciated
Do you mean camber? This / \ ? Is your car low low low? When I did my rear brakes mine was very bad. I had to raise my car and get a camber kit. Now I can lower it again since I got the camber kit.
TOE- The tires pointing outward or inward ("gaite" of the tire, Helps in turning, bad for staright)
CAMBER- The vertical tilt inward or outward (Helps corner better with slight neg. camber, too much slippery dippery doo)
Caster- How much the tires lean forward or backward. (Driving Straight ahead stability, ease of turning effort)
Ooooooh. Yikes. Did you move the arm that connects to the frame near where the cables go through. Man that arm is hard to explain.....
The one that says do not remove bolt, did you move it?
http://tjshondas.20m.com/cgi-bin/i/rrdisc/t_arm.jpg
dng
May 25, 2004 07:29 AM
