Which Rockford amp will go to a stable 1.2 ohm load?
Old Dec 16, 2002 | 08:53 PM
freeplay's Avatar
Default Which Rockford amp will go to a stable 1.2 ohm load?
I want to run 3 HE's in a series. I think it will be at around 1.2 ohms. I know a Sony 1200watt class D amp will push them. Will a bd500.1? Thanks
Old Dec 17, 2002 | 10:04 AM
gokuson's Avatar
Default Re: Which Rockford amp will go to a stable 1.2 ohm load? (BoostInBoi)
i don't know if u can get 1.2 ohm load on series, but on parallel, u could depending on what ohm ur subs are.
If i remember correctly, HE's are single voice coils(4 or 8 ohms) so for
4 ohms 1/(1/4+1/4+1/4) = 1.333 ohms
8 ohms 1/(1/8+1/8+1/8) = 2.667 ohms
so depending on your ohms on the subs, if it were 8 ohms each, then the bd500.1 will work, because it is stable at 2 ohms.
if yours are 4 ohms then i'd consider getting a 1ohm stable amp like JL i think they make a 500.1
i hope this helps
Old Dec 17, 2002 | 08:42 PM
ROCcityRSX_S's Avatar
u need to find an older rf amp, from like 98, they could handle 1 ohm, and they were NASTY, tons of power and way under rated
no_skillz
Audio / Security / Video
Jan 31, 2007 09:29 AM
89hbcivicguy
Mar 3, 2005 09:12 AM
deeweezy
Jun 23, 2004 02:36 PM
cd5_2NR
Apr 24, 2003 02:02 PM
