****need help with turbo install****
Old Dec 16, 2002 | 07:31 PM
Boltz's Avatar
Default ****need help with turbo install****
will anyone help me out that has AIM?
ive tried imagestation, etc. for uploading pics but it never works for me. would anyone let me IM them 2 pictures of my turbo kit setup i have labeled so i can learn what i need to do about my current setup, i think i am missing pieces, or am retarded... thanks in advance to anyone that wants to lend a hand.. ...
PLEASE HELP
IM BroPo9420 : :
THANKS
AIM ME @ BROPO9420
[Modified by Civic420, 10:32 PM 12/16/2002]
Old Dec 16, 2002 | 08:02 PM
The Mole's Avatar
Default Re: ****need help with turbo install**** (Civic420)
[Modified by The Mole, 12:18 AM 12/17/2002]
Old Dec 16, 2002 | 08:07 PM
Boltz's Avatar
Default Re: ****need help with turbo install**** (The Mole)
here she is... i dont know how to get the circular piece into that rectangluar thing for the exit of the oil on the turbine.... thanks for the help!
Old Dec 16, 2002 | 08:10 PM
CzanSOHC's Avatar
you need an oil outlet flange. you can get it here, $13. http://www.roadraceengineering.com/f...andgaskets.htm
Old Dec 16, 2002 | 08:12 PM
Evil EG's Avatar
DAMN! Talk about not 56k friendly at least use .jpg's.
The part you need is here
http://64.225.76.178/main.htm
Part Number is 20259
But anyway where in IL are you, if your close and need any help with the install I could give you a hand.
AIM: TurboGSR2000
[Modified by BVM, 11:20 PM 12/16/2002]
Old Dec 16, 2002 | 08:14 PM
inspyral's Avatar
You need this flange:
http://store.yahoo.com/cheapturbo/t3bilaloilre.html
Old Dec 16, 2002 | 08:19 PM
The Mole's Avatar
Default Re: ****need help with turbo install**** (inspyral)
on me for using a bmp, i hosted for him and didnt even realize the format, i changed to jpg now
chris
Old Dec 16, 2002 | 08:38 PM
DeepSi's Avatar
1. Yes you need the flange mentioned above
2. Yes the part that you say weld to oil pan is correct.
3. For non-IC turbos there are only 3 pipes, but for some reason those dont look like it. The bottom one hooks up to the turbo. the top one connects to the TB. the middle one looks like a pipe for an IC piping.
Old Dec 16, 2002 | 09:23 PM
1.8T_EG's Avatar
Default Re: ****need help with turbo install**** (DeepSi)
... wow, great info (pix)...
Old Dec 16, 2002 | 09:28 PM
Ivan's Avatar
senior gold member
Default Re: ****need help with turbo install**** (1.8T_EG)
yeah it makes it so much better with pics
Old Dec 17, 2002 | 04:15 AM
Boltz's Avatar
Default Re: ****need help with turbo install**** (Ivan)
thanks to everyone that replied... im gonna see if viren will quick ship me one of those oil flanges now. my only problem as of now that i still have is my intercooler piping... also, where does it hook through on the drivers side? i know it doesnt go through where a/c is supposed to be and the only other hole i have is for my wiper fluid... ill take a pic of that today and get it up aound 2pm cnt..
thanks
Old Dec 17, 2002 | 04:17 AM
Boltz's Avatar
BVM - i am located in geneva(60134), which is a small town. it borders st. charles.... lemme know how far you are
justin
Old Dec 17, 2002 | 04:52 AM
Evil EG's Avatar
I live in yorkville (60560) which is like 15 - 20 mins away.
[Modified by BVM, 7:54 AM 12/17/2002]
Old Dec 17, 2002 | 05:17 AM
B18Flip's Avatar
Default Re: ****need help with turbo install**** (BVM)
bump...marking for my install. Good info guys
Old Dec 17, 2002 | 06:07 AM
TurboedGSR's Avatar
the piping you have is only for the outlet of IC to TB. I ordered mine from viren too. that 90degree bend goes between the other two pipes. you'll be able to tell when you get them on there.
BTW when you install it, let me know if if fits right. for some reason mine wasnt angled correctly right at the tb bend
i dont know if you can see how its bent in some.
Old Dec 17, 2002 | 08:42 AM
mos's Avatar
mos
Default Re: ****need help with turbo install**** (TurboedGSR)
That RRE flange is an aluminum piece with a 1/2" NPT thread on it. It comes with a 1/2" NPT to 5/8" barbed brass adapter. The AN fitting you have will not thread into the RRE flange, so you need to get an adapter to go from 1/2" NPT to your AN fitting if you want to use the RRE flange.
Old Dec 17, 2002 | 08:54 AM
Wanna lude too.'s Avatar
Default Re: ****need help with turbo install**** (mos)
Hey i'm from around St. Charles.I drive a red prelude sh, we should meet up, i'd like to check your car out.
Old Dec 17, 2002 | 11:24 AM
Boltz's Avatar
Default Re: ****need help with turbo install**** (Wanna lude too.)
TurboedGSR - thanks for the help dude, so i take it i am missing 2 or more pieces that connect the inlet side of the intercooler to the output of the compressor?
bvm - thanks for the help meng! i should be ok with me and my mechanic working on it, but another set of hands is always welcome if you would like to join us.
Wanna lude too - small world huh? is your prelude stock? i have no problem meeting up sometime, im also starting a exclusive car club next season, what i am excluding is slow cars. lol.. how old are you? do you still go to the stc high school(s)?
later
Old Dec 17, 2002 | 01:53 PM
justinCO's Avatar
Here is what my IC piping looked after I got it all finished and had it welded. You can get an idea of what all the pipes are that you will need. It is only missing the pipe that came off the turbo outlet. You should be able to understand where the other pieces fit in the car.
Justin
Old Dec 17, 2002 | 06:34 PM
Boltz's Avatar
Default Re: ****need help with turbo install**** (justinCO)
thanks, bump
Old Dec 18, 2002 | 11:40 AM
My ludes got i/h/e/ pullies and vafc. My best is a 14.9 and that was before the vafc and header. I want to go turbo and would love to check your car out. I'm 20 and i just started making fat cash at the Chillis across from the mall. I went to Kaneland and know i'm at Waubonsee.
ekb16a
59
Jun 21, 2007 10:02 PM
turbohf
Jan 24, 2007 09:19 PM
boostedblkef
Sep 7, 2006 10:03 AM
alfee
Mar 28, 2004 10:11 PM
