!!!!!Please Help Me FIX my CIVIC!!!!!
Old Dec 16, 2002 | 09:16 AM
mariopaul's Avatar
Default !!!!!Please Help Me FIX my CIVIC!!!!!
the car is a 91 civic lx it was dying so i put a new fuel filter on it and that wasn't the problem so i but a new distributor cap and rotor on cause they were bad and it ran fine for 2 miles then died and it has greak spark and alot of fuel comes to the TB hose, what is my next move guys!!!!! i broke the little plastic rotor shield is that a problem? i can't see fuel mist when i crank it over with a plug out either..... ANY IDEAS? I NEED HELP!!! i just typed like 500 words in this thing a second ago about this whole ordeal but it erased them said i had to many capitols!!!
[Modified by mariopaul, 6:16 PM 12/16/2002]
Old Dec 16, 2002 | 09:18 AM
upstatecrx's Avatar
Default Re: !!!!!Please Help Me FIX my CIVIC!!!!! (mariopaul)
take the cap back off and check to see if the rotor is ok. i've heard of the screw coming out. also are you throwing any codes. (is the check engine light on)
Old Dec 16, 2002 | 09:29 AM
4drEF's Avatar
Keyboard Humorist
How was it dying? What are the symptoms?
I don't have the plastic rotor shield in my distributor anymore... makes no difference.
All 4 plugs are sparking just fine? Make sure!
Crank/cam belt timing is correct?
If you pull the plugs and srank it a few times you should be able to smell the gas in the cylinders. If not, I would think you have a clogged injector since you say you have no fuel problem up to the TB hose. (I assume you are 100% sure that fuel system -ie main relay- is working just fine).
Old Dec 16, 2002 | 09:35 AM
mariopaul's Avatar
Default Re: !!!!!Please Help Me FIX my CIVIC!!!!! (4drEF)
i only took 1 plug to check but it was sparking fine, and it was running fine so i am assuming the timing belt is fine, it wouldn't spark if the belt was bad would it?
well the setscrew in the rotor had stripped so i replace the cap ans rotor the rotor was so worn it was actualy wobblying on the shaft and destroyed itself and the old cap,
the dying was only at low rpms after it was hot, and if it left it sit and run if i hit the gas it would die, but i would try to accelerate on the freeway it would chug like bad fuel or water, but it has a fresh tank and some heet in it, after i changed the parts it ran great for 2 miles then died. how do i get to the injector?
Old Dec 16, 2002 | 09:36 AM
mariopaul's Avatar
what do you mean by the man relay? wouldn't it not have pressure if that was bad?
Old Dec 16, 2002 | 09:55 AM
mariopaul's Avatar
top
Old Dec 16, 2002 | 10:41 AM
Snapshift's Avatar
Maybe your distributor is shot, does your idle get all choppy, does it run like youve got water in the fuel system?
Old Dec 16, 2002 | 11:02 AM
importfan85's Avatar
Default Re: !!!!!Please Help Me FIX my CIVIC!!!!! (Snapshift)
When my hatch kept dying, it ended up being the igniter. There was a recall on it way back, like in '93. Don't know if that's the prob., but you might want to check.
Old Dec 16, 2002 | 01:23 PM
4drEF's Avatar
Keyboard Humorist
Default Re: !!!!!Please Help Me FIX my CIVIC!!!!! (importfan85)
He ays he gets good spark now. That rules out the ignitor. It pretty much rules out the entire ignition system actually.
He isn't getting the fuel smell from the cylinders when he cranks without plugs. My guess is fuel related.
Old Dec 17, 2002 | 10:12 AM
mariopaul's Avatar
i went ahead and replaced the main relay and that didin't fix it but it ran like the other guy said so it might be my disi
projectej8
Sep 2, 2005 10:04 PM
EX-T
Apr 10, 2005 02:18 PM
junktronic
11
Mar 27, 2005 12:05 PM
90SiHatchbk
May 24, 2004 07:31 PM
schpreck@cox.net
Mar 27, 2003 04:26 PM
