Q About VTEC Engagement
Hey guys and girls,
Aside from RPM, are there any other factors that dictate whether VTEC is engaged (e.g. temp)?
When I took my ITR out for a spin at lunch, I swear the VTEC failed to turn on once. Next time I tried, the VTEC engaged. Just want to make sure!
Thanks.
Eric Lee 303
[Modified by ericlee303, 5:58 PM 12/16/2002]
Thanks.
Eric Lee 303
Well, it's not rocket science, but like with everything.. you can't just force something to work automatically... you have to let it settle in first.... (Analogy: you just don't go out and start physical activities without a nice stretch and warm-up)... same thing with your car... if you try to engage VTEC without warming up the car properly... your car will choke or it won't even reach that rev limit (8000+ RPM)... so just go off your temp gauge on the cluster... and you'll be ok...
I believe the variables are
Engine Temp (Water?)
Throttle Position
Oil Pressure.
Power FC over rides these VTEC kicks in immediately which isn't really a great idea.
Throttle Position
Oil Pressure.
Chpwhtek
Mar 19, 2012 04:48 PM
