Doh! Over-torqued 2 Cam Holder bolts... Snapped :(
Old Dec 15, 2002 | 10:45 PM
Tofurky's Avatar
Default Doh! Over-torqued 2 Cam Holder bolts... Snapped :(
the rear middle cam holder - over-torqued the 2 bolts, they snapped, and i hate my life.
and i also hate this shitty haynes manual...
what can i do about this? i'm half ready to call it quits and tow this piece of **** to import builders.
Old Dec 15, 2002 | 10:47 PM
psi420's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (Ruckus138)
Shoulda bought a Helms, and two steping your torque sequence helps.
Did you use a torque wrench?
And MOST important, did you add oil to the threads and head of the bolt?
wHOAlly's Avatar
mask the whole head/area off, and use an extractor on that sob, i had to do it on 2 bolts too cuz the mother ****** tq wrench was broken!!!!
Old Dec 15, 2002 | 10:51 PM
Tofurky's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (psi420)
yeah we used a torque wrench. and added oil to the threads & head of the bolt...
the haynes said to torque it 86 lbs, but i only did 76 because it sounded a bit much... and it looked like that was still enough to say oomph to my bolt.
Old Dec 15, 2002 | 10:52 PM
The_Head's Avatar
The same thing happened to me when I was helping reassemble my motor. Had to drill out the part of the bolt stuck in the head. 2 hours of wasted time. Be very careful about metal shavings.
Old Dec 15, 2002 | 10:53 PM
psi420's Avatar
OMFG!
Cam Bolts are not supposed to be that much.
Sounds like you applied head gasket torque specs.
Old Dec 15, 2002 | 10:56 PM
boostaholic's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (xThexHeadx)
Woa, 86 ft-lbs is way too much on those little bolts. Go back in the helms and read the torque setting again, should be in inch-lbs. On the bright side, get a good bolt extractor and unless they're in there really good they will come right out.
Old Dec 15, 2002 | 10:59 PM
Tofurky's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (boostaholic)
yeah, i seriously need a helms manual
Old Dec 15, 2002 | 11:02 PM
Tofurky's Avatar
just out of curousity, is the car drivable without those two bolts? i mean the cams are already pretty snug, but i'm pretty sure i know the answer.
finals week, what a great time for this to happen...
Old Dec 15, 2002 | 11:25 PM
Speed PHreak's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO, yup you knew the answer.
What you need is an INCH POUND torque wrench, the cam bolts on LS engines are 96 INCH/lbs which translates to 8 ft/lbs. I think the VTEC heads are like 14 ft/lbs. Either way you shouldn't use a regular 10~120 ft/lb torque wrench on them. Go get/borrow the right tool for the job, or you'll be sorry.....
Old Dec 15, 2002 | 11:27 PM
psi420's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (Speed PHreak)
22 actually.
Old Dec 15, 2002 | 11:39 PM
Tofurky's Avatar
thanks guys... looks like i'll be getting myself an easy out tomorrow morning from OSH,
and i hope acura stocks these little bolts
Old Dec 16, 2002 | 06:56 AM
legendboy's Avatar
I wouldn't try an easy out to start with!!! I did the exact same thing and this is what I did. Go to your local industrial supply house and get a couple brand new speed steel or cobalt reverse drill bits. Use a drill on very very slow speed and you should be able to turn the peice right out since the head of the bolt is what gives it its staying power. If you try using easy outs you risk making an even bigger mess since there are oil journals down inside some of the bolt holes. May the force be with you...
Old Dec 16, 2002 | 07:45 AM
earl's Avatar
Sometimes you can use the proper torque, do it in two steps, use anti-seize on the threads and the bolt still breaks on you. Never gets any better.
Old Feb 25, 2005 | 10:51 PM
i3yron's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (Tofurky)
Same thing happened to me today **** hayns !!!!Luckly i only broke one bolt one bolt and easily got it out with a reverse thred kit i stole from my pop.....
Old Feb 26, 2005 | 10:50 AM
bradford's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (i3yron)
I snapped one those myself, I was kinda freaking out, and didnt know what to do till my boss came by and just unscrewed it with a pick. it should be able to come out easily, without the head on the bolt the threads arent tensioned.
Old Feb 26, 2005 | 11:05 AM
adictionbass's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (bradford)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradford &raquo;</TD></TR><TR><TD CLASS="quote">without the head on the bolt the threads arent tensioned.</TD></TR></TABLE>
That is the key.
Old Feb 26, 2005 | 05:31 PM
hondaguyef's Avatar
Default Re: Doh! Over-torqued 2 Cam Holder bolts... Snapped :( (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes you can use the proper torque, do it in two steps, use anti-seize on the threads and the bolt still breaks on you. Never gets any better.</TD></TR></TABLE>
That makes me feel much better. Don't ask me how I know though
Phil
GsrIntegra789
Sep 28, 2006 07:26 AM
I got a honda
Oct 19, 2005 08:06 PM
92eg6lsvtec
11
Jul 9, 2005 12:57 AM
92-LS-Civic
Oct 7, 2004 07:47 AM
xXx Justin xXx
Apr 1, 2004 07:20 PM
