Torque specs
Old 07-05-2005, 09:06 PM
92eg6lsvtec's Avatar
Default Torque specs
im putting my lsvtec back together so i was wondering if anyone can point me to a site or thread with all the torque specs for doing thise. rods bolts, mains, head, etc.. i did search but any help would be awsome
Old 07-05-2005, 09:08 PM
Luserkid's Avatar
Default Re: Torque specs (92eg6lsvtec)
http://www.helminc.com/
Old 07-05-2005, 10:09 PM
Default Re: Torque specs (Luserkid)
no thats to order a manual. i dont wanna oreder one i just wanna see the specs online thanks tho.
Old 07-05-2005, 10:28 PM
my house has wheels on it
BrokeAssWhiteboy's Avatar
why are you builing an engine with out the specs right there in front of you ?
any ways........
main caps 56 lb-ft
rear main seal 8 lb-ft
oil pump 8mm bolt 17lb-ft, 6mm bolt 8lb-ft
oil scren 9lb-ft
oil pickup 8lb-ft
oil pan 9lb-ft
baffle plate 8lb-ft
stock ls rod bolts 23lb-ft
vtec head bolts: first 22lb-ft, then 60lb-ft
cam caps and oiling plates: 8mm bolt 20lb-ft, 6mm bolt 7.2lb-ft
cam gears 41lb-ft
valve cover 7.2lb-ft
hope this helps
Old 07-06-2005, 10:13 AM
Default Re: (BrokeAssWhiteboy)
yea thats awesome thanks
Old 07-08-2005, 08:46 AM
Default Re: (92eg6lsvtec)
o is there a certian pattern on the head bolts?
Old 07-08-2005, 09:23 AM
chinkest_raver's Avatar
yes there is, there are numbers on the head if you look, if you even tried looking. Please go out and buy a Chilton book, it'll tell you everything you need to know! good luck!! By the way its only running around $15 for the book, I assume you do have $15 right??
Old 07-08-2005, 11:54 AM
Default Re: (*****est_raver)
thanks i prolly will
Old 07-08-2005, 12:11 PM
AutoXer's Avatar
Chilton and Haynes suck; and frequently have wrong information. Go to the link above and get the actual factory manual.
Old 07-08-2005, 05:36 PM
transpar_nt's Avatar
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">Chilton and Haynes suck; and frequently have wrong information. Go to the link above and get the actual factory manual.</TD></TR></TABLE>
Old 07-08-2005, 05:59 PM
Master23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">im putting my lsvtec back together so i was wondering if anyone can point me to a site or thread with all the torque specs for doing thise. rods bolts, mains, head, etc.. i did search but any help would be awsome</TD></TR></TABLE>
Damn man, sounds like a serious build but are you going to be checking the clearances before putting the main caps together? What about piston to valve clearances? Are you just planning to torque it up and get it over with?
Old 07-09-2005, 12:57 AM
Default Re: Torque specs (Master23)
nah dude it will be done right. or at least i hope. still can anyone just tell me the right pattern?
GsrIntegra789
09-28-2006 07:26 AM
Tofurky
02-26-2005 05:31 PM
92-LS-Civic
10-07-2004 07:47 AM
tvrsir
08-08-2004 11:56 PM
Four Door LS VTEC
02-13-2003 05:13 PM
Quick Reply: Torque specs
