Hallman recalibrated Autometer A/F guages for more accuracy...
anyone have experience w/ these? I guess they've modified them for more accurate readings.
scroll down past the boost controllers to the guages...
http://www.hallmanboostcontroller.com/order.html
Have you used it? Has anyone used it and compared it to real wideband? Dammit. I'm sick of people spouting off info based on presumptions. Sure the stock 02 sensor is focused on the wrong part of the a/f range but this dude's concept sounds semi-solid.
I bought one of those awhile back, it works as advertised. A lot better than guessing .75 to .98v with 5 green leds. Its pretty much the same as this one: http://www.gadgetseller.com/gauges/index.htm
I'll sell it to you for $60 shipped, white face phantom series. excellent condition
Have you seen the stock O2 sensor's graph of voltage vs a/f ratio? It doesn't matter what you read it with...you could read it with a voltmeter. It still doesn't make a difference because the O2 sensor's output voltage can be the same for many conditions.
Crappy pic, but you get the idea.
At .9 volts, you could be at 10:1 a/f or you might be at 12:1 a/f. The stock O2 sensor cannot accurately tell the difference.
Sonny
I don't think he was asking for a debate which is better wideband vs modified gauges. I think the question is "is it more accurate than the regular a/f gauge", the answer would be YES.
The answer if its better than the wideband is NO.
Here's a better pic and it would suggest that voltage goes up as a/f ratio gets richer. I've tested the unit vs my techedge wideband, at .91v I would be around 11.8:1-12.2:1 and at .88v would yield between 12.8-13.0:1. I did not see a big fluctuation between the 2.
I know it's no wideband, but would you suggest it?
cant you buy a prebuilt unit from tech edge and then the sensor and the totoal be around 500 to 600ish..or even cheaper? maybe i'm on crack....
what about the greddy air/fuel gauge. doesn't that come with a wideband?
are the vx O2 sensors really a true wide band o2 or are they just a little better then the other models O2's
typesguy
Dec 18, 2003 08:46 PM
CBR
Nov 30, 2002 05:24 PM
