heres what i got so far, any input? (trbo setup)
Ok, I have a 90 prelude si with the JDM b20a engine(nothing special). I sent the block out to GE for re-sleeving, pistons, rods, o-ringed, just basically having the entire bottom built for boost. Heres the rest: T3/T04E 60 trim .82AR , msd sport compact igniton , blaster 3 coil , FMIC from ebay (pretty big and very nice), tial 35mm red top wastegate, rc550 injectors, walbro 255 fuel pump, custom header, turbo XS type h blow off valve, and some gauges and a timer, new radiator, new o2 sensor. Here is what I STILL NEED TO GET; SAFC, cartech adjustable FMU, then exhaust piping and IC piping and a stage 3 clutch. Anybody have any input on what elses I should look into? I dont have much cash left to play with, thanks alot guys, I realy appreciate it.
so your saying not to use an fmu at all? and by custom header = I got all the flanges I need from cheapturbo.com and my brother in-law is a professional welder and he is going to weld it up all nice nice for me. As for the FMU, how come you suggest not using one? Thanks for you input.
with 550's and a fuel pump you shouldnt need the fmu...and instead of the safc, id say go with a nice standalone system like hondata for a couple hundred more, it will be much better for you...
Hondata offers nothing for my car, and I cant find an after market ECU anywhere. But as for the FMU, are you guys sure I wont need it? Thanks again guys.
mamaboy
Dec 1, 2002 08:07 AM
i recomend full-race.com
