front transmision mount..... look!
Old Dec 15, 2002 | 01:15 PM
USDM 4G VTEC's Avatar
Default front transmision mount..... look!
k i am posting this on this forum bc its strickly applies to 4G Cable trannies....
and all the guys that might have it are here...
anyways... my front mount of the tranny that goes to the crossmember its broke... its tilting my engine to much while shifting...does anybody that did B series swap have any of them laying around that i can buy off u for a good price... i only need that lil part... anyone with one let me know.... PM me or post it or aim me @ chacofg
thanxs people
Old Dec 15, 2002 | 01:22 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: front transmision mount..... look! (JDM EF9)
Take a pic of what you need
I just bought a d15b2 swap and most likely I have the part or whatver you are looking for
Old Dec 15, 2002 | 02:16 PM
Default Re: front transmision mount..... look! (MugenHonda)
k.... its a half moon looking mount... goes in front of the transmision... if u open ur hood... look between radiator and engine... under the fan .. theres a mount that goes from the crossmember to the tranny... i need that mount!....
Old Dec 15, 2002 | 02:43 PM
MugenHonda's Avatar
get back to me tom
When I get my car back i will probably have it
Old Dec 16, 2002 | 05:58 AM
Doodoo's Avatar
I have one now. ---->PM
Old Dec 16, 2002 | 06:22 AM
keithv's Avatar
Default Re: front transmision mount..... look! (Doodoo)
please post here once you have found the part. thank you.
Old Dec 16, 2002 | 06:56 AM
sporkcrx's Avatar
Default Re: front transmision mount..... look! (breaka_1_9)
If it's just the rubber inside do what I did and buy ES engine mount inserts....straightened that **** right up for around $20 (for both front and rear mounts)
Old Dec 23, 2002 | 06:50 AM
still no luck
somebody should have one please... make that my xmas present... i need it still.... dooodoo u got a PM....
Old Dec 23, 2002 | 06:55 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Go to http://www.suspension.com and order the ES kit for $15 bucks. It is an insert kit that will fix broken bushings, so not only will your front one be fixed, but theres also a rear insert that is cake to install. It will make your car feel much better upon accelleration.
-Todd
Old Dec 23, 2002 | 07:15 AM
keithv's Avatar
Default Re: front transmision mount..... look! (Count Blah)
do you need the metal housing or the rubber part???
Old Dec 23, 2002 | 07:26 AM
well i need the metal part that houses the rubber mount (with the rubber)... its like a half moon shape , mount that bolts into the tranny front side...
[Modified by JDM EF9, 11:34 AM 12/23/2002]
Old Dec 23, 2002 | 07:41 AM
Blown90hatcH's Avatar
D series or B series?
Old Dec 23, 2002 | 07:42 AM
Default Re: front transmision mount..... look! (Blown90hatcH)
D series.... for my Z6....
i am about to call the guys from http://www.suspension.com and order that ES kit for motor mounts its $15.. anybody think its going to fix my broken mount?? i guess ill be calling them
[Modified by JDM EF9, 11:43 AM 12/23/2002]
Old Dec 23, 2002 | 07:53 AM
wronghand's Avatar
I will check tonight and see if I have one. I am pretty sure I do. If you don't fine one IM me tonight and we can work out the specifics. I could get it in the mail tomorrow.
Old Dec 23, 2002 | 07:57 AM
wronghand... thanxs a lot tho! but with i called http://www.suspension.com and ordered the Energy Suspension Motor mount inserts.. they were $15... i guess that was my best bet...
thanxs everyone that helped me.... peace
Old Dec 23, 2002 | 09:00 AM
8 9 si's Avatar
Just let you know, that's insert mount will help, but it's squeak like a f%$%. I used to have one, and can't stand the squeak. I also try the ghetto method by refilling the hole by using the 3M glue thing. It's help, but it doens't last that long. Finally, I have to fork out some dough to buy the OEM stock front tranny moun at the dealer. Good luck
Old Dec 23, 2002 | 09:09 AM
wronghand's Avatar
No problem man. Just let me know if you need it in the future.
atleast-3
Sep 23, 2007 12:07 AM
Danny_EJ
Sep 3, 2006 05:23 AM
mykal
15
Sep 25, 2004 08:11 PM
ILuvJDMITR
May 16, 2004 08:15 AM
