electronic vss wiring
Old Dec 15, 2002 | 07:50 AM
irtep's Avatar
Default electronic vss wiring
i was reading all the post from my search for the vss wiring and i'm still a little confused. the black wire is ground. the yellow with the white is 12v power. the yellow with the blue is vss. i got the ground and the power but the vss, is it suppose to go to the ecu or is it suppose to go to the cluster. i'm i suppose to split the signal after. btw it's a vss from an eg.
Old Dec 15, 2002 | 09:03 AM
ghettocrxsi's Avatar
Default Re: electronic vss wiring (irtep)
You run a wire from the vss to the cluster and from the cluster it goes to the ecu.. and make sure you have a switched power so it turns on when the car is on.. off when the car is off yada yada have fun with your new cluster
Old Dec 15, 2002 | 09:10 AM
MNTuner's Avatar
I always try to keep all the electronics the same generatoin. Unless there is a performance benefit. (I.E. GM's 3 bar MAP sensor ) I would suggest getting the same VSS sensor that came with the ECM you are using.
[Modified by MNTuner, 6:12 PM 12/15/2002]
Old Dec 15, 2002 | 02:07 PM
irtep's Avatar
Default Re: electronic vss wiring (MNTuner)
so it goes from the tranny to the cluster. then how does it get to the ecu? do you just splice the wire and run it to the ecu?
Old Dec 15, 2002 | 02:32 PM
Jaker's Avatar
There is already a speed pulser wire going from the ECU to the cluster. EF's come that way. You just need to tap into the speed pulser wire with the VSS signal wire. It does not matter if you do it at the cluster or the ECU.
Old Dec 15, 2002 | 05:09 PM
4drEF's Avatar
Keyboard Humorist
Sooo... what do YOU do when you have a USDM 4g and you want the JDM cluster? The USDM uses a cable drive from the tranny to the speedo and the VSS is built into the cluster. The JDM has a VSS mounted on the tranny and runs a wire from there to supply the ECU and cluster with speedo info.
Anyway - tap the wire anywhere you want. There is a wire that feeds the stock VSS signal from the cluster to the ECU so you can tap the wire anywhere you want - the signal will still feed both the ECU and cluster.
Old Dec 15, 2002 | 07:03 PM
irtep's Avatar
Default Re: electronic vss wiring (4drEF)
thanks for all the help.
Lazysk8r2
Feb 19, 2012 06:51 AM
french_yogi
Apr 18, 2011 06:24 PM
civickid03
Jul 20, 2006 06:03 PM
eskimo_usd
Jun 9, 2006 03:04 AM
Manolo
10
Jul 12, 2005 03:16 AM
