Bad ECU? VTEC surges and cuts out intermittently......???
Old Dec 14, 2002 | 11:41 PM
TurboIntegra's Avatar
Default Bad ECU? VTEC surges and cuts out intermittently......???
Ok before I say anything::
I HAVE OIL.
NO CEL'S
All wiring is OK
I have a p28 with HONDATA. vtec surges as it pulls.... It like cuts out intermittently. I have heard of this happening on stock ECU's and Hondata ECU's. So I am very confused.
This guy has the EXACT same problem as me:
https://honda-tech.com/zerothread?id=232874
"Actually I think I may have figured the cause of the problem.
The ecu and vtec work fine - but only when driving very very mildly. So, I'm saying that if I drive down the road and I'm just cruising normal, and then decide to wind out a gear - the vtec will work perfect.
But... If I'm in vtec for a long period of time and I'm driving the car very hard the vtec will start to cut out more and more as I drive it harder and harder, until finally it throws a check light and I have no vtec at all.
Let the car sit for 20 mintues or so and go out and then drive normal, wind out a gear... vtec is fine, works perfect. Then start driving hard and it starts not working again (studdering and cutting out)"
SOMEBODY PLEASE HELP ME. THIS IS BECOMING FRUSTRATING
Old Dec 14, 2002 | 11:45 PM
MK Ultra's Avatar
Default Re: Bad ECU? VTEC surges and cuts out intermittently......??? (TurboIntegra)
Have you checked your fuel delivery components?
Just one more thing to check off the list before concluding it's the ECU.
Old Dec 14, 2002 | 11:47 PM
Default Re: Bad ECU? VTEC surges and cuts out intermittently......??? (MK Ultra)
Yes, fuel setup is fine. Excellent actually.
Old Dec 14, 2002 | 11:55 PM
MK Ultra's Avatar
Hmm. Could it be a problem with heat soak? Is your cooling system up to snuff with the rest of your setup?
Just throwing out some suggestions.
Old Dec 15, 2002 | 12:57 AM
Yeah I have a HUGE Fluidyne!
I am not sure how temps could effect the vtec turning ON and OFF.
I am thinking it is more of a ECU problem.
XxfatlacexX808
Mar 12, 2013 07:18 AM
ef kyle
Sep 14, 2006 11:04 AM
boosted k20
Jul 21, 2005 07:15 PM
TurboIntegra
Dec 15, 2002 05:06 PM
