fuel pressure info???
Old Dec 14, 2002 | 09:28 PM
EF8CR-X218's Avatar
Default fuel pressure info???
what is a good psi setting on a B&M commandfo fuel flow modifier? i have a crx si with the D16A6 motor. header, intake, and an exhaust is all the upgrades that i've done to my car.
shout out to all the homies rolling in EF's
Old Dec 15, 2002 | 05:41 AM
USDM 4G VTEC's Avatar
Default Re: fuel pressure info??? (EF8CR-X218)
u should run no more than 42psi.. lil more and u will be lil over the rich line....
Old Dec 15, 2002 | 06:44 AM
PhatOptimo's Avatar
Do a baserun on a dyno with the fuel pressure @ 40 with vaccum line attached. You will see that if you lower it to about 37 with vaccum line attached you might pick up a few ponies 1-3.
sliver666
Dec 18, 2008 12:07 PM
6_GeArEd_TEG
Nov 27, 2004 09:57 PM
Joel_MN
Jun 14, 2003 12:03 PM
IgniteTeg
May 29, 2002 11:08 PM
