Power FC w/ 3 bar map sensor
Old Dec 14, 2002 | 05:41 PM
MiraiZ's Avatar
Default Power FC w/ 3 bar map sensor
Has anyone got a Power Fc configured to use a 3 BAR map sensor? If so, what are the settings you used?
Old Dec 14, 2002 | 06:24 PM
philo's Avatar
Default Re: Power FC w/ 3 bar map sensor (MiraiZ)
from what i understand it needs to go back to a PowerExcel shop and the one in Houston want $300 for to enable the 3bar sensor.
Old Dec 14, 2002 | 06:56 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Power FC w/ 3 bar map sensor (philo)
DAMN IT..... i talked to the guy with the RX-7 with the Power FC and the GM 3 Bar tonight, and i forgot to ask him what he had to do..... you have to change some setting, i can ask him next week, i am sure i will see him, he is always at the shop that is fabbing my IC piping
Old Dec 15, 2002 | 05:20 AM
MiraiZ's Avatar
sigh
There is a place for map sensor settings...I just need to know the specs for it, and you don't have to pay PowerExel to get it!!!
Old Dec 15, 2002 | 05:29 PM
boosted3g's Avatar
you wont have to send your FC back to them. You will however had to alter the map. The cells will jsut have different values.
Old Dec 23, 2002 | 02:26 PM
MiraiZ's Avatar
Default Re: Power FC w/ 3 bar map sensor (boosted3g)
TTT....anyone have the settings for this?
Old Dec 23, 2002 | 03:14 PM
Boostless97Lude
Guest
Posts: n/a
ok, what he told me was fairly vauge, and he can't remember his settings, but he said he actually had to try a few things
Old Dec 23, 2002 | 04:23 PM
boosted3g's Avatar
Default Re: Power FC w/ 3 bar map sensor (Boosted97Lude)
There is a few ways to do it. One way is to jsut tell it you have smaller injectors than what you really have. Or i you want to go and change all the values in the grid that is fine, it will work that way too. You can send it to XS to have them recalibrate everything which about all they will do is this. When you do it the way i said the #10 PR level will not be the crossover from vacuum to boost. It will be somewhere around 7 or 8.
Old Dec 23, 2002 | 05:27 PM
turbotypeR@SPEC's Avatar
25 Year Member
i have that setup on my car.all you have to do is go into settings and chose PIM volt.scroll down to number 5 which is option 4.you don't have to do anything else.just make sure it stays on option 4 and hit prev to go back to wherever you want.
Old Dec 23, 2002 | 11:10 PM
philo's Avatar
Default Re: Power FC w/ 3 bar map sensor (turbotypeR)
the load values on all the maps need to be rescaled... that can only be done by a power fc shop.
Old Dec 25, 2002 | 03:24 PM
MiraiZ's Avatar
thanks...this is what Ineed to know
CaliforniaDad
Feb 15, 2013 06:49 PM
jdm.fanatic
Jun 16, 2007 09:33 AM
turbolshatch
Feb 2, 2006 06:06 AM
turbotypeR@SPEC
Jan 9, 2002 04:29 AM
joeyitr309
Oct 21, 2001 12:04 PM
