ls/vtec rods
Old Dec 14, 2002 | 02:31 PM
shilohcrx's Avatar
Default ls/vtec rods
i found a set of type r pistons with a ceramic top coat i was gonna get them and the guy said that crower didnt make a rod for the type r pistons so could i use a stock type r rod or do i need to get ls rods and will the ls rods work on a type r piston another ? if i get a vtec piston do i need to run a vtec rod if you could just give me some tech on the bottom end it would help out alot i got a 1994 gsr head and a 1991 ls bottom and will earls fittings work for the external oil line and if so do you have part#'s thanx
Old Dec 14, 2002 | 02:54 PM
b19coupe's Avatar
Default Re: ls/vtec rods (shilohcrx)
With the LS crank you have to run the LS rod, VTEC rods are too long. You can use the LS rod with a GSR/Type-R/CTR piston, you just have to machine the small end of the rod to accept the pistons. The rod is too fat to fit without machining. I ran LS rods in my LS/VTEC with CTR pistons and this setup worked fine. I would recommend upgrading to ARP rod bolts.
Old Dec 14, 2002 | 03:41 PM
jdmDXrex's Avatar
Default Re: ls/vtec rods (b19coupe)
Old Dec 14, 2002 | 10:44 PM
shilohcrx's Avatar
Default Re: ls/vtec rods (jdmDXrex)
i already puchased arp rods for the ls rods is this part # correct arp-208-6401 they are 9mm bolts and im looking for some crower rods and another question will ls crower rods work with the type r pistons and is grinding the top of the rods something i can do or do i need to let a machine shop do it
Old Dec 15, 2002 | 04:49 AM
b19coupe's Avatar
Let the machine shop do it. It is not that expensive, and you don't want to cut corners on something as important as engine internals.
Old Dec 15, 2002 | 07:30 AM
shilohcrx's Avatar
what is the engine bore size on the b18a and when pistons bore size do i need to get and will the earsl fittings work for the external oil like i got work from someone that z10 is where i needed to get the fittings thanx for all the help fellas
Old Dec 15, 2002 | 08:25 AM
94TealGSR's Avatar
Where's the punctiation!?!? In all of your posts combined the only punctuation I see is a question mark!
Old Dec 15, 2002 | 09:33 AM
Ek-CoolGuy's Avatar
how did you like the CTR pistons in your LSV? What other mods did you have and what kinda numbers were you getting in the 1/4th and dyno? Just curious cuz I'm buidling my block right now w/ some CTRs too.
Thanks
Old Dec 15, 2002 | 10:25 AM
b19coupe's Avatar
Default Re: ls/vtec rods (Ek-CoolGuy)
175 whp at Import Builders on ITR pistons. Never dynoed with the CTR's. No 1/4 mile times either. I just built the motor to run when my GSR block was out; it's my daily driver, so it can't be down.
[Modified by b19coupe, 7:26 PM 12/15/2002]
almostjdmeg
16
Aug 20, 2015 11:10 AM
sanegb16
Apr 24, 2008 06:22 AM
killerpenguin21
Jul 5, 2006 09:09 PM
notsure
Aug 6, 2003 09:38 PM
Yellb16crxsi
May 19, 2003 12:19 PM
