problems with my IAB. HELP!!!!!!!
Old Dec 14, 2002 | 02:30 PM
fastwanabe's Avatar
Default problems with my IAB. HELP!!!!!!!
I hookup my IAB to A17 however the solenoid is not getting the signal to close. I tested the wires that go to the solenoid and wiried them to the battery and it worked fine. I know thw wires are good and that the solenoid is good and I have tested the wires with my MM. I currently have them on a relay to open when vtec kicks in!!! any suggestions? help
Old Dec 14, 2002 | 02:43 PM
Kataku2K3's Avatar
Default Re: problems with my IAB. HELP!!!!!!! (fastwanabe)
How do you know that they aren't closing??? when you start ur car they are shut by the vacuum... When your ECU tells them to open up the IAB solenoid breaks the vacuum and they pop open... I'm just curous how you know that they aren't opening... Lemme know... Peace
Old Dec 14, 2002 | 03:19 PM
fastwanabe's Avatar
Default Re: problems with my IAB. HELP!!!!!!! (JDMspecEG6)
as far as I know the vacuum thingy is suppose to pull the secondaries shut when I startr the car, and it isnt do that, it stays in the same(OPEN) position ALL the time.
Old Dec 14, 2002 | 03:41 PM
Kataku2K3's Avatar
Yea exactly.... The vacuum shuts the butterflies when you start the car and when the IAB solenoid gets a 12 volt signal it releases the vacuum and lets them open up... A stock GSR ECU IAB x-over is at ~5700rpm
[Modified by JDMspecEG6, 4:42 PM 12/14/2002]
Old Dec 14, 2002 | 08:03 PM
fastwanabe's Avatar
but my problem is that the secondaries are not closing!! WTF I know thw wiring is good but for some reason the ECU is not closing them when I start the car. I assume the ECU grounds the solenoid cercuit to allow vacuum to close the secondaries then cuts ground to release the butterflies open.
Old Dec 15, 2002 | 02:11 PM
Kataku2K3's Avatar
My bad fastwanabe.... I read that totally wrong... So when you start your car up they don't get sucked closed?? I would check into the solenoid itself if all your wiring is good.... Good Luck
EJ8Squad919
Nov 24, 2012 11:10 AM
spags930
11
Jul 12, 2010 04:46 PM
h22lude317
Jan 10, 2009 01:29 AM
xtreme-customz
Nov 10, 2005 03:20 PM
xd69
May 11, 2005 10:06 PM
