what should fuel pressure be at idle on a gsr motor boosted..
doesn't really matter what pressure you have it at. the range would be 35-65psi or thereabouts. what matters is what you are using to control your injectors ie, a standalone computer vs a vafc or inline pump/fmu as your delivery method.
my personal choice is to use a standalone, larger injectors and keep the fuel pressures near stock 40-50psi.
niedejb
Mar 28, 2002 02:06 PM
