Limited Slip Differential
Old Dec 13, 2002 | 11:22 PM
HondaH22A's Avatar
Default Limited Slip Differential
Anybody have any suggestion or advice for a good LSD? It's for a 2001 Honda Accord EX V6 coupe.
Thanks
Old Dec 13, 2002 | 11:26 PM
briq4's Avatar
Default Re: Limited Slip Differential (HondaH22A)
Just out of curiosity, does the traction control suck that bad? Doesn't the 01 V-6's come with that standard? I would think it would have the same type of effect? I.E. wheel slippage detected and then controled thru braking of the slipping wheel thereby throwing torque back to the wheel with more grip? Just wondering...
Old Dec 14, 2002 | 12:06 AM
iam7head's Avatar
Default Re: Limited Slip Differential (briq4)
I actually know someone have a 6th gen 4cyl have a LSD installed.
Want to send him a email? let me know.
Old Dec 14, 2002 | 03:10 AM
91 EX-R's Avatar
A limited slip is more of a performance enhancement than a traction control device.
Old Dec 14, 2002 | 08:17 AM
psyphre's Avatar
Default Re: Limited Slip Differential (91 EX-R)
pardon my lack of knowledge, but can you put a LSD in an automatic?
Old Dec 14, 2002 | 09:51 AM
KTeller8's Avatar
Default Re: Limited Slip Differential (psyphre)
good thought
<--------really wants to know
Old Dec 14, 2002 | 01:01 PM
iam7head's Avatar
Default Re: Limited Slip Differential (KTeller8)
I dont think you can get much tq steering at all with accord at tranny lol
I not sure tho'
Old Dec 14, 2002 | 04:29 PM
Razor's Avatar
well i do know there are JDM automatic h22 trannies that come with LSD...
btw i dont think any accord came with traction control, most of the time traction control is for RWD cars, the accord is FWD.
Old Dec 14, 2002 | 06:01 PM
OEMaccord's Avatar
Default Re: Limited Slip Differential (Razor)
01+ v6 accord have TC and all 7th gen except dx and lx i-4 come with TC
Old Dec 14, 2002 | 06:47 PM
MyBigNut's Avatar
i believe the prelude with the ATTS system is a traction-control type thing....
Old Dec 14, 2002 | 10:11 PM
HondaH22A's Avatar
Default Re: Limited Slip Differential (MyBigNut1)
ATTS is not the same as LSD or traction control. ATTS only works when the car understeer while cornering.
So are there any LSD for V6 Accord with auto tranny? I haven't seen anyone using that, that's why. Do you think the factory Integra Type R LSD would fit into the Accord?
Old Dec 15, 2002 | 06:23 AM
jweller's Avatar
absolutely not
I'd check with quaife. they make a good LSD for a lot of hondas. you shold be able to use one from any of the C block motored cars I'm guessing. CL/TL(2nd gen)/Odessy(2nd gen)/MDX all use the same basic motor, so i'd guess their tranny is the same.
ask at accordV6.com those guys might know better.
Old Dec 15, 2002 | 07:30 AM
urbanlegend21's Avatar
New User
Default Re: Limited Slip Differential (jweller)
I do not believe it is even traction control, i believe it is a system that uses ABS to help turn the car with brake modulation
Old Dec 15, 2002 | 12:11 PM
carolinaACCORD's Avatar
#1: Yes, they do offer LSD's for automatics. Some of the best places to get it them are Quaife (although it may be custom from them) and Protech ( very good). They will cost you though.
#2:
ATTS doent only work while understeering, if the ATTS system senses a tire slipping, it will transfer the torque to the tire with traction (hence, Automatic Torque Transfer System) It's a lot like LSD.
[Modified by carolinaACCORD, 4:12 PM 12/15/2002]
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
vodkaTM
Jul 29, 2009 09:09 PM
jdm type s
Dec 27, 2004 01:36 AM
John
Oct 7, 2001 10:51 AM
Reverend
Aug 2, 2001 07:32 AM
