Hayden Tranny Cooler
Old Dec 13, 2002 | 11:20 PM
HondaH22A's Avatar
Default Hayden Tranny Cooler
Hi, my friend have a 2001 Honda Accord V6 EX Coupe and he wants to purchase the Hayden tranny cooler. Anybody know the size of the tranny cooler for that car? Where can he purchase it and how much is it? Does tranny cooler really help?
Thanks.
Old Dec 14, 2002 | 12:23 AM
iam7head's Avatar
Default Re: Hayden Tranny Cooler (HondaH22A)
https://honda-tech.com/zerothread?id=335194
do a search brother..
the small one should cover enuff for passenger car.
I assume your friend is not towing sh-t around right?
read it and see if you have any Q's..
here some insight
you are running tranny cooler additional to factory tranny cooler.
I highly recommending your friend to get a inline ATF filter.
Old Dec 14, 2002 | 12:24 AM
iam7head's Avatar
Default Re: Hayden Tranny Cooler (iam7head)
this guy have a stunna style tranny cooler
Old Dec 16, 2002 | 08:06 AM
HondaH22A's Avatar
Do you have to remove the factory tranny cooler to install the Hayden tranny cooler? Thanks.
Old Dec 16, 2002 | 08:17 AM
carolinaACCORD's Avatar
you have to reroute the hoses
Old Dec 16, 2002 | 09:30 AM
Desslok's Avatar
Default Re: Hayden Tranny Cooler (carolinaACCORD)
Are there any cons to installing one? More likely to leak, blocks radiator flow, etc?
Old Dec 16, 2002 | 02:21 PM
iam7head's Avatar
Default Re: Hayden Tranny Cooler (sp)
LOL no i run the aftermarket tranny cooler additional to factory one.
leak? just check the cramp every month.
All the hardware is included and installation is fool proof.
the hardest part is locat the oil return line.
believe me..if you have a crapomatic..get one.
I ordered the inline ATF filter too, too bad the christmas rush took
like 1 month to get it over here.
I paid 1500 for tranny rebuild last summer on my beater..mainly due
to our enemy..HEAT.
Another reason would be that i am planning to run a 65shots.
any questions?
Old Dec 16, 2002 | 02:22 PM
iam7head's Avatar
the hose itself is not very very high pressure and all that..
you can feel the oil line is much more cooler after you install it..
Old Dec 16, 2002 | 02:28 PM
Desslok's Avatar
Col, I'm thinking of getting one too, after all the horror stories about Honda Autos. Especially since it's my daily driver and need it to last.
iam7head's Avatar
here my little dummies' diagram (STOCK)
flow-----> flow--->
{tranny}..........(oil supply line)......(factory tranny cooler).....
.F....<Aftermarket TrannyCooler>........(oil return line)..........
<-----flow <----Flow
*F=inline atf filter, install it after tranny cooler.
There's two way to install it, one is replace it completely
and the other is add it on to the factory tranny cooler.
Old Dec 16, 2002 | 02:29 PM
iam7head's Avatar
Yes...get a inline filter to remove all the metallic sh_t. which is the really killer beside the heat.
the stock tranny filter is a joke...
Old Dec 16, 2002 | 02:30 PM
iam7head's Avatar
The tranny cooler i got is about 50 bucks..
inline filter is about 25 bucks
pretty low cost protection plan to me
Old Dec 16, 2002 | 02:49 PM
Desslok's Avatar
Yeah sounds good, do you have a link to where you got yours?
Old Dec 16, 2002 | 05:09 PM
iam7head's Avatar
LOL for tranny cooler GO see those hot rod places..
try bigger auto part store
small 15inch one will do just fine for passenger car.
I having hard time buying inline ATF filter locally
so i ordered mine online.
Hehe..It was on my last post..."how to install tranny cooler"
Old Dec 16, 2002 | 10:43 PM
HondaH22A's Avatar
15", is that like the smallest one? They fit the 01 Accord V6 EX coupe right?
Old Dec 16, 2002 | 11:06 PM
raceACCORDingly's Avatar
all the info you will need for 6th gens: http://www.v6accord.com/forums/showt...=&threadid=543
i have a stacked plate style tranny cooler on my 5th gen that i picked up from a local auto part store. you can get any size as long as you can fit/mount it. i got a mid-sized vehicle one.
Old Dec 17, 2002 | 07:41 AM
iam7head's Avatar
Default Re: Hayden Tranny Cooler (raceACCORDingly)
Yep...middle size would be good for v6 but i have a i4..so smaller one
will do it.
Old Dec 17, 2002 | 12:46 PM
jweller's Avatar
Nothing is fool proof for a sufficiently talented fool
Old Dec 17, 2002 | 06:18 PM
iam7head's Avatar
Default Re: Hayden Tranny Cooler (jweller)
LOL...right.
Old Dec 18, 2002 | 11:27 PM
HondaH22A's Avatar
That was a pretty helpful info, thanks a lot but they didn't mention the size that would fit the 2001 V6 coupe, anyone know what size would fit that car? Thanks again.
Old Dec 18, 2002 | 11:43 PM
iam7head's Avatar
15inch is consider small..but mine is i4 and I am running it as additional tranny cooler so it's alright.
GO grab a midium size for v6 good luck
Old Dec 18, 2002 | 11:45 PM
HondaH22A's Avatar
Oh okay, thanks a lot.
Old Dec 19, 2002 | 07:00 AM
b18bvtec4drteg's Avatar
There is a write up here for the installation on the CL-S from cl.com (Silverbullet)Should be somewhat similar for the exception of the body panels etc. This is a very good walkthru. I dont think the Hayden has the orifice like the B&M.
http://home.satx.rr.com/silverbullet/tranny.htm
slo_ej8
Apr 8, 2008 05:04 PM
twitchzx6rr
Nov 20, 2007 04:06 PM
