how does one remove valves?
Old Dec 13, 2002 | 10:32 PM
JeremyL's Avatar
Default how does one remove valves?
i got my head a couple nights ago and i took it apart today, the injectors and rail came out easy, IM and TB all related parts came off pretty easy, the roller arms arent even attached so those came off, but i dont see how to get the retainers out to get to the springs to get the valves out...do i need a special tool?
also when i get all my new parts in and put the head back together how do i make sure its all "in time"?
thanx for the help guys
Old Dec 13, 2002 | 11:58 PM
Lsos's Avatar
Default Re: how does one remove valves? (JeremyL)
You need a spring compressor. Compress the spring, and it should be easy to take the keepers and retainers out. I speak from experience on a Mitsubishi engine....
[Modified by Lsos, 8:59 AM 12/14/2002]
Old Dec 14, 2002 | 01:04 AM
Shawn C's Avatar
In The Garage
Default Re: how does one remove valves? (Lsos)
to make sure its in time, put the bottom end at top dead center (TDC) (put the 1 & 4 pistons up top, and there is a notch on the crank pulley)carefully sliding a long screwdriver or rod down the spark plug hole and cranking the engine with a wrench helps too. then make sure the head is at TDC (there are arrows on the cam gears, they should point up) then slip on the timing belt. MAKE SURE everything is tight, most importantly the timing belt tensioner, and it should be ready to go. just remember to prime the fuel system several times before you try to crank it.
Old Dec 14, 2002 | 08:17 AM
JeremyL's Avatar
Default Re: how does one remove valves? (22lbGS-R)
would having aftermarket pistons (endyn rollerwave) and rods (eagle) effect any timing placements? i saw the arrows that point up on the stock cam gears but how do i make sure theyre perfect or can i just eye ball it? im pretty sure i can make sure the block is in time cuz i did change the timing belt on my Porsche and i used the notch on the crank pulley that youre talking about
im more concerned about the valves and cams being in place more so than the block
nightkidracing
Jun 21, 2009 02:21 PM
sillvercivicgsr
Feb 21, 2004 08:19 AM
JeremyL
Dec 13, 2002 12:09 PM
TheLostOne
Dec 11, 2001 05:40 PM
Phatwhippin_CRX
Dec 8, 2001 06:52 PM
