Spring rates. How much is too extreme for the street?
Paragraph Alert
Ok I know alot of you care about comfort so let me make this clear. I DON'T GIVE A CRAP ABOUT IT. Since my car is a daily driver though I need it to be safe on the streets and I can't be coming off the ground every time a hit a pebble. I'm really thinking in the area of 12-14kg/mm if not more. Your opinions please.
Paragraph Alert
what do you do with the R besides drive it on the street
is it tracked often?
How are the roads in AL?
Based on my 1.5+ yrs of driving in ATL on Zeal Function S (12/8 spring rates, albiet in a Civic Si and not an ITR), I'd say 14kg/mm on the front is no problem for street driving, but anything above 8kg/mm on the rear is pushing it - you're gonna be too bouncy.
[Modified by kengs, 1:39 AM 12/14/2002]
sounds like 12/8 swift springs with those s6 are in order
i wish i could run 12/8 up here in NY
Paragraph Alert
Ha i can only imagine trying to drive with those rates on ohio roads. I swear ohio has to have some of the most beat up, pothole filled roads in the U.S.
[QUOTE]How are the roads in AL?
Based on my 1.5+ yrs of driving in ATL on Zeal Function S (12/8 spring rates, albiet in a Civic Si and not an ITR), I'd say 14kg/mm on the front is no problem for street driving, but anything above 8kg/mm on the rear is pushing it - you're gonna be too bouncy.[QUOTE]
so are you saying that to stiff in the back makes a car bouncy?
Paragraph Alert
Don't forget that he will be doing Q-mile racing, and with the stiffies it might hurt his ETs...
.....for a good all-around setup, the s6 w/ 12f, 8r will be perfect.
Just swap the springs f-->r and run 8kf, 12kr... That'll be a little tailhappy (so drive carefully on the streets), but great for drag and autox and roadracing alike...
I have the KGM DR Race's (ITR-spec). They're actually softer than the stock ITR springs driving on the streets, as long as you stay off of the bump stops.
In slower, tight turns, the back feels like it wants to keep squatting further...like it doesn't ever hit the full squat threshold. Turnpikes and off-ramps can be taken with confidence.
why are you guys recommending stiffer fronts than rears to him?...where have all the racers gone? ...rhetorical question...
because it makes things more interesting.
heaven knows I can't exceed the speed limit...I'd fall asleep if it weren't for oversteer.
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
since we're in the U.S. , i'll use our system of measure, lbs...
i run 500lbs front and rear.....never given me a reason to hate my decision, besides the fact a larger sway in the rear would be nice. To bad im unemployed and can't afford such luxuries.
Btw, track events, and general street driving....
hispanic panic
26
Apr 19, 2019 06:16 AM
litterbox
11
Nov 28, 2005 12:18 PM
ActiveAero
15
Nov 11, 2003 10:42 PM
