LSD: Can I swap the tapered bearings for roller bearings?
I found an LSD I will probably buy. The only thing is, it uses tapered bearings:
The one I need uses roller bearings:
Can I simply swap the bearings? Please help me out quick!
Thanks. Sorry for posting in here..
Awesome question! I've never tried that... does anyone know if this will work? Setting preload can be a real pain.
Yes you can do it and yes it will work fine. Hopefully you wont have a problem getting the bearings off (roller). I swapped them for mine and haven't had one problem.
I'll be taking some pics and making a GOOD "how to" when I do this whole thing. There's gonna be alot of pics.
if your trans was using the tapered bearings to begin with, you will have to replace
the shims as well. but if you want to switch because your trans previously used
the ball bearings then its no problem. just make sure to check the clearance
Ok. Say I get the bearings swapped - now setting the preload? What exactly is that?
Do I need to do that if I use the roller bearings?
I need answers. I dunno what to believe. I just want to do it right, and make it exactly like it was stock, then shut the damn tranny and leave it alone.
Well wait for someone else to confirm. I swapped them on mine, and my LSD feels as though is still works peachy. I did exactly what you are doing... so take that FWIW. Good luck.
PS - what happened to ur stock LSD?
to set the clearance properly using shims
LMAO!!!
