Just finished swap, idle won't come down?
Okay, I just finished replacing a 96 integra Ls' engine with a 92 Ls. I didn't have an obd2 oil pump so the ckf sensor did not get transferred over (cel 54 for the ckf).
Well my concern is the car idles at over 1000rpm even after adjusting the idle screw all the way down. After giving it a little gas, the idle will come back to about 1200 but surges up and down between 1200-1300rpm for about twenty seconds before becoming steady again at 1200 (everytime it gets gas). Why is the idle so high? WHat could I check?
I remember filling the empty radiator up the first time and started it up, the coolant didn't seem to flow (no extra water/coolant needed and none flowed into the overflow reservoir) it just took the gallon and a little water; usually on other engines I've done, when it started, the water flowed and needs topping off.<--could this be a factor to my idle problem? what could be the cause of this?
I bled the coolant, carb cleaner on every vac hoses (no leak), throttle cable adjusted to Helm's spec. Nothing. Idle still over 1000rpm-still surges lightly after rev drops (after revving it). Another thing weird is that my coolant don't seem to wanna flow; I have the heater on and cap open when bleeding and it never take up any coolant
. Since the first fill and initial startup, usually I'd have to add water after starting up on a coolant flush, etc., but this time the fluid just stays there at top; don't seem to flow into the block--overflow reservoir also empty. Any ideas on these two problems that is stressing me the f*%k out??
First check the engine grounds, but i'm not thinkin that this is the case... Check your thermostat and bleed the coolant again... There may be air pockets in the coolant causing it to open and close your FITV making the idle surge... If that isn't the problem then check the TPS voltage by measuring it off the center wire in the connector... Make sure that there is no more than 0.5vdc with the throttle closed... I always set it to 0.45... Good Luck
What about the cams? i thin ki heard some where that a stage 3 cams make the idle higher? please correct me if i'm wrong i need to learn more about cars.
Not really... Maybe a bit lumpy over an OE cam but that's what you get from high lift cams... My friend's race motor with ITB's and SK2 stage 3 cams has a pretty good idle.. Peace
also, make sure you purge the air out of the cooling system by loosening the bleeder valve on the water neck that connects to the upper hose.
boostin4drcivic
14
Dec 19, 2003 07:08 AM
chirp2hrd
19
Sep 19, 2002 09:24 PM
