Tach install with new Si cluster
im getting an Si cluster for my 6th gen hatch...and i dont have a tach on my current cluster...is it just plug and play...or does it need modification?
it should take you about 5 minutes. its a simple plug and play mod. There are 2 screws holding on the bezel, just unscrew those and pull out the bezel, then there is 4 screw holding in the clusters just take those out and and unplug your cluster. Then plug in the si cluster and put it all together again.
make sure you change the fuel gauge to show how much fuel you have in your car, or else it will be inaccurate.
the gauge will read it correctly.. plug and play.
Nocturnal
Aug 31, 2003 07:37 PM
