Building a ZC????
92 DOHC ZC in a 92 vx hatch (EH2)
A while a go a friend mentioned something about some supra piston and b16a rod build for the zc....anyone got info or link to this.....
Anyinfo on zc internals would be good too.....I've searched online and have seen many many different opinions...I want to know from experience....someone help me out...
I'm eventually going turbo....but for now I just want a rebuilt motor....I'm going to do a new head gasket and replace all seals, rings, etc.....I just want to upgrade the internals to handle boost.....I'm only going to run 9 or 10 psi daily and track...I just want my car to be reliable.....
Thanks...
Thanks...
https://honda-tech.com/zerothread?id=340384
Thanks...anymore info on internals anyone???
Edit: I did search no post reguarding this....it could be my work computer though...someone post a couple more threads if possible thanks..
[Modified by SlowCivicHmm, 8:52 PM 12/13/2002]
https://honda-tech.com/zerothread?id=267641
is where the rod and piston info is. I don't think that setup will help you unless you are ready to boost because your cr will be lower. Most info you find on d16a1 blocks will apply to the zc.
pugsleeuk
Mar 28, 2006 04:39 AM
