Turbo choice
Old Dec 13, 2002 | 07:04 AM
chidoks's Avatar
Default Turbo choice
Hey,
Alright, I have a '94 integra LS with suspension, brakes and all that stuff...
I am currently dropping in and wiring my H22 in the car, I want to be able to hit mid to low 11's with my setup in this car on slicks(doesnt matter which size)...
Over the summer the motor is going to be built up with:
JE .020 over 9.0:1 CR pistons
Crower Rods
ARP Rod Bolts
ARP HeadStuds
GE Sleeves
720CC Injectors
Quaiffe LSD
Action Clutch Stage 2MD
Honda Saver valve springs
AEM Standalone...
H23 tranny for better traction
DSS stage 3 axles
Traction bars
What turbo size should I get? I want some pretty decent spool up on the street and i want to be able to hit my goal of low 11's to mid 11's on slicks which would probably require about 400-450whp....
I am thinking a t3/60-1 w 0.82a/r turbine
or
a t4/60-1 w 0.70a/r turbine
Remember its a 2.2liter motor and i want some decent spool up on the street with a pretty good top end... thanks
Old Dec 13, 2002 | 08:59 AM
Speedworks801's Avatar
Default Re: Turbo choice (chidoks)
If you really only want 400-450whp (not that that's low or anything) You should stick with a .63 A/R for the best spool. This setup will make 550-600whp.
Old Dec 19, 2002 | 07:45 AM
chidoks's Avatar
Default Re: Turbo choice (Speedworks801)
so then a t3/60-1 w/ 0.63 a/r should be fine for my goals?? What stage wheel should i run? Would I need to run a stage 5 wheel? thanks
[Modified by chidoks, 4:46 PM 12/19/2002]
Old Dec 19, 2002 | 07:49 AM
ArizonaTurbo's Avatar
The .63 A/R housing may be a liitle too small for 500 hp. You may want to consider the .82 A/R housing. You will have a bit more lag, but it will make the power you want. You can always get a ball bering center section to help aid lag as well as sending the turbine housing to Extrude Hone. Thsi will help spool by about 400-500 rpms and will net ~ 2-3% points of efficiency.
Old Dec 19, 2002 | 08:00 AM
chidoks's Avatar
Default Re: Turbo choice (TurbochargedSER)
so basically, i would want a t3/60-1 w/.82a/r and a stage 3 wheel? As an upgrade, i could add a ball bearing center section...right??
Old Dec 19, 2002 | 08:10 AM
You have the displacement. I suggest the .82 A/R turbine housing to make 500+ whp.
94delsol-b16a
Mar 12, 2010 06:15 PM
kprashad
Mar 4, 2009 11:36 AM
DjBurns
Dec 15, 2005 01:08 PM
fastludeh22
Sep 23, 2002 08:49 PM
sweettooth
Apr 15, 2002 03:54 AM
