coilover install problem
Old Dec 12, 2002 | 07:25 PM
00fbp's Avatar
Default coilover install problem
i tried to intall some coilovers on my 93 cx today but i didnt get to finish because i couldnt take out that one bolt to take apart the assembly. i compressed the spring already but then when i tried to turn that one nut, the whole thing spins. do you think i messed it up??
Old Dec 12, 2002 | 07:27 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: coilover install problem (00fbp)
normal. Hold the shock w/ something and try again.
Old Dec 12, 2002 | 07:48 PM
Civichatch2k's Avatar
yep that does sound normall just try to hold the shock down and that should help.
Old Dec 12, 2002 | 07:50 PM
-Gambit-'s Avatar
which nut are you talking about?
Old Dec 12, 2002 | 07:51 PM
racecarpete's Avatar
Default Re: coilover install problem (Civichatch2k)
are you talking about the top nut that holds the entire shock/spring/hat assembly together? If so, did you use an allen wrench in the center of the shaft or no?
Old Dec 12, 2002 | 07:53 PM
00fbp's Avatar
Default Re: coilover install problem (SilverCivic2k)
yeah the one that holds the shock/spring/hat assembly. and no i didnt use the allen wrench at center. was i suppose to? sorry never did a spring/coilover install before.
Old Dec 12, 2002 | 08:04 PM
-Gambit-'s Avatar
yea you need to use an allen wrench in the center to hold the nut, then it will all come apart.
Old Dec 12, 2002 | 08:15 PM
00fbp's Avatar
Default Re: coilover install problem (gambit33)
thanks all for your help
Old Dec 12, 2002 | 08:22 PM
smnowell's Avatar
Yeah, use the proper size allen wrench and a 14mm open-end wrench. It will come off easily! You might want to spray that nut down with some WD-40 or brake cleaner if you have some...
Old Dec 12, 2002 | 11:14 PM
Vanilla4215's Avatar
Default Re: coilover install problem (b16a ferio)
be sure not to strip that allen wrench hole, or else you're in a world of hurt.
Old Dec 13, 2002 | 12:02 AM
Achenar's Avatar
5mm allen wrench and you'll be okay!
Also, in my experience, the Honda shocks are assembled very tightly, so try not to break any skin when holding onto that allen wrench, maybe hold onto it with a pair of pliar (I bent an allen wrench 45 degrees doing this!)
-a
apwhat
Honda S2000
Jan 5, 2012 02:12 PM
oakpwr
Jan 27, 2007 01:08 PM
.brad
Aug 13, 2003 03:09 AM
MachAF
Mar 23, 2003 08:20 AM
MachAF
Mar 23, 2003 03:42 AM
