Compression #'s, revisited.....
I asked about good numbers for a compression test a while back, for my H23, and one guy got 150-160's on his before turbo, and everyone else said they should be around 210 or so. i finally got around to doing a dry compression test, looking for the source of a skip, and I got the following averages outta 3 tests each cylinder:
1st - 166
2nd - 167
3rd - 175
4th - 175
Does this sound about right? Anyone got a site or something to back up the acceptable numbers?
1st - 166
2nd - 167
3rd - 175
4th - 175
Are these numbers really low? What should they be?
The symptoms are since I got a new engine dropped in. I am thinking it might be plugs:
- An occasional skipping that occurs at 2/3 throttle or less, and only every few revolutions. It makes the car buck lightly, more so as I press on the throttle. Then, when I'm near WOT, all four kick in and it runs great. It goes away when I floor it. Also, it seems to do it more so when I leave my car overnight on a cold rainy night and I crank it up in the morning. I thought it might be electrical, as in wiring problems, but it will go away when floored. I have replaced my wires, dist. cap, rotor, and I thought plugs, but the shop switched those while it was in the shop, so I am thinking it might be b/c they dropped one when putting them in. I've also done the compression test, and tested the fuel press., which cam out to be a healthy 36 psi at idle. Any ideas?
usually if the #'s are within 10 of each other it's ok... 5 or less is best... anything over 10 and you might wanna check things for leaks.. such as valve components, head gasket, etc
you're fine... those are ok numbers for a higher mileage H23A.
As long as the car runs good, and the numbers stay within the 10 range of eachother, you'll be ok.
drumminforev
13
Sep 19, 2006 05:42 PM
Hondizzle!
Sep 13, 2005 09:13 AM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
