what springs with stock shocks?
Old Dec 12, 2002 | 11:15 AM
LiLn81224's Avatar
Default what springs with stock shocks?
anybody have any experience with aftermarket springs that work well with stock shocks?? or should i go the other way and get shocks with stock springs?? i dont have enough money to get both right now and was just wondering which way is better...thanks
Old Dec 12, 2002 | 11:30 AM
Mojo-Jojo's Avatar
Default Re: what springs with stock shocks? (LiLn81224)
Well, if you want to lower for looks...just don't.
If you want to lower for performance you really really should get new shocks with them.
If you want better handling, and you're only going to buy one of the two things, get some good shocks.
If you get springs that are too stiff for your stock shocks to handle, your handling will suck, and you'll blow your shocks eventually, and you'll have to buy some anyway.
If you get good shocks, they'll probably be adjustable, and so you might be a little overdamped at times, but that's better than a bouncy ride with shitty handling and blown shocks.
Old Dec 12, 2002 | 11:46 AM
ill phil's Avatar
Default Re: what springs with stock shocks? (Mojo-Jojo)
Well I've still got my stock shocks on some Ground Control coilovers with rates of 500/600. Still holding up really well, I'm surprised- not that I want to keep it that way, I was just budgeted at the time. Get some shocks at the same time.
Old Dec 12, 2002 | 12:38 PM
Cynical 1's Avatar
I'd buy springs and shocks at the same time. You'll have to have them off to get just springs, so why not do both?
Stock shocks suck with upgraded springs. The ride will be worse, and the shocks will wear out faster, and you'll have to change them again.
Just buy some performance gas shocks, like KYB or Tokico. They won't break the bank and will work a lot better.
Old Dec 12, 2002 | 12:49 PM
Ktulu's Avatar
Default Re: what springs with stock shocks? (Revolveu2)
You might want to check out the h&r oe sports. I believe they drop no more than .5 inch and work great with stock shocks. Their website is down right now though.
Old Dec 12, 2002 | 03:10 PM
DC Sports EJ8's Avatar
I have had the Eibach Pro-Kit springs on the stock shocks for approximately a year and a half now. I think that the shocks are still fine, but I am going to replace them anyway with TOKICO Illumina in a few weeks. How much do you want to lower your car? If you want to lower it no more than 1.5 inches, then get new springs now (I suggest the Eibach Pro-Kit) and new shocks later, when you have the money. If you want to lower it more than 1.5 inches, then get new shocks now and new springs later. You can also wait until you have enough money to buy both at the same time.
Old Dec 13, 2002 | 01:25 AM
EddieHatchBlack's Avatar
Default Re: what springs with stock shocks? (DC Sports EJ8)
I don't recommend stock shocks w/ lowering springs. It's your car, do what you wish.
genia99civic
Suspension & Brakes
Dec 18, 2008 12:22 PM
Hazem
Oct 27, 2004 03:27 PM
PnX-R
Apr 29, 2002 04:54 PM
ebelp
Feb 16, 2002 07:40 PM
RuskeR
Jan 14, 2002 02:03 PM
