To thouse with Excedy clutch....
Old Dec 12, 2002 | 11:01 AM
AssPenny's Avatar
Default To thouse with Excedy clutch....
I've had mine on for about 20k miles now and i've noticed that the pressure plate is starting to hit the clutch like when it was first installed. Anybody else with an excedy clutch have to adjust the throw on the push rod over time?
Old Dec 12, 2002 | 11:22 AM
sackdz's Avatar
Default Re: To thouse with Excedy clutch.... (AssPenny)
Nope :\
Old Dec 12, 2002 | 11:39 AM
98R-1144's Avatar
nope... not yet at least. i adjusted it after the clutch install...that wasabout it. did u tighten the pushrod bolt?
Old Dec 12, 2002 | 11:42 AM
AssPenny's Avatar
Default Re: To thouse with Excedy clutch.... (98R-1144)
I thought... I've been to lazy to check it.
Old Dec 12, 2002 | 12:04 PM
ITR-01-0977's Avatar
New User
I had to adjust mine after about 10000 miles....I think if you adjusted the throw right on the edge of touching (like I did) you will probably have to adjust it eventually due to wear of the disk. At least it is an easy fix.
Old Dec 12, 2002 | 12:08 PM
madtownhonda's Avatar
Never had to adjust mine at all, not even after install...I guess I was lucky
Old Dec 12, 2002 | 12:32 PM
hooptie157's Avatar
Default Re: To thouse with Excedy clutch.... (madtownhonda)
mine just squeaks alots
Old Dec 12, 2002 | 12:36 PM
Smitdog's Avatar
Default Re: To thouse with Excedy clutch.... (hooptie157)
Had to adjust mine when i installed it. It rarely ever makes the noise anynmore but sometimes it does. I am not happy with the Exedy anymore. As soon as the holidays are over I will be ordering an ACT Clutch.
Exedy is s great stock replacement but just not what I am looking for Grabing wise with a clutch. I am goign to go with the ACT Extreme PP and Hybrid Street Disc. Plus when u install almost any other clutch there is not adjusting the push rod and al the other little probs. Overall not happy with the Exedy.
Old Dec 12, 2002 | 12:53 PM
The Mole's Avatar
Default Re: To thouse with Excedy clutch.... (Smitdog)
Eric used one on his new motor in his Ek....hopefully he'll have no troubles
chris
Old Dec 12, 2002 | 01:51 PM
Bbasso's Avatar
"Overall not happy with the Exedy. "
ME TOO!
Old Dec 12, 2002 | 02:02 PM
junglistgsr's Avatar
Default Re: To thouse with Excedy clutch.... (Bbasso)
i need to figure out how to adjust my pedal, anyone have instructions? I cant find my helms for the life of me.
Old Dec 12, 2002 | 04:46 PM
Tommy_Gunns's Avatar
Interesting...perhaps I should look into purchasing a differenct clutch.
What other clutch has "stock" pedal feel and good durability?
ME TOO!
Old Dec 12, 2002 | 05:10 PM
Q-OnE's Avatar
Default Re: To thouse with Excedy clutch.... (The Mole)
yea...just get it checked quick. don't want anything bad happeneing down there. my friends fo some reason had bolt loose and then all of a sudden he couldn' get into 1st or 2nd. sucks to take off in 3rd with a d16 motor hahah
Old Dec 12, 2002 | 05:37 PM
Smitdog's Avatar
Default Re: To thouse with Excedy clutch.... (Tommy_Gunns)
ME TOO!
I would deff go with a ACT Heavy Duty Pressure Plate with a Street Disc. The Pedal with the HDSS setup feels just like stock maye a hair stiffer. DC2R320 has this an it is perfect if u want the stock pedal feel. I am going to go with the Extreme PP and the Street Disc.
Old Dec 12, 2002 | 05:47 PM
woodog's Avatar
the pedal feel and control is almost like stock with the act hdss.
no adjustment of the pushrod necessary.
since i only have about 3k on the clutch, cannot comment on durability.
[Modified by dc2R320, 9:48 PM 12/12/2002]
MiNeSEK
19
May 11, 2013 12:05 AM
ge_ej1
Apr 9, 2008 10:02 AM
Cyber ITR
Nov 24, 2003 12:08 PM
ActiveAero
Jan 7, 2003 04:25 AM
bluemex
Sep 1, 2002 09:04 PM
