do i need to break-in a 6puck clutch ??
i just wondering if i have to break-in a 6puck clutch, i know i do if i have an organic material clutch disk
thanks
thanks
Re: do i need to break-in a 6puck clutch ?? (Day Walker)
I never have. Hell I've never broken in any clutch haha.
I put about 20k miles on one and never broke it in. Only replaced it when I rebuilt the motor.
Re: do i need to break-in a 6puck clutch ?? (shermanyang)
ceramic 6 puck clutch does not need to be broken in. most organic types or kevlar should be broken in, or so ive been told
by the way what kind of disc do you use integra_98gsr
Re: do i need to break-in a 6puck clutch ?? (quickergixxer)
ACT unsprung ceramic 6 puck.
I've never been a fan of clutch breakin. Drive it around the block and make sure it is engaging and disengaging properly and then rail the **** out of it.
Only major clutch problems I've had have been stripping the splines on the clutch disc and having an ACT pressure plate collapse. Both of which were due to a faulty disc and pressure plate.
Re: do i need to break-in a 6puck clutch ?? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">I would to be safe. </TD></TR></TABLE>
Re: do i need to break-in a 6puck clutch ?? (JDogg)
Yea, i only break in organic full face disks, those stopped holding long ago. I have a ceramic 4 puck now, but i drove it normal for about 50 miles due to the face that i didnt resurface the FW because it only had about 4k on it from my other clutch. But basically, I just make sure its holding, and then its ***** to the wall from there.
Brett
Brett
Re: do i need to break-in a 6puck clutch ?? (yellowhonda88)
yeah, i never REALLY broke mine in. I just didn't drive it hard or let it see boost for about 300 miles... but then again it only lasted 3000 miles, Thanks act
Re: do i need to break-in a 6puck clutch ?? (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus »</TD></TR><TR><TD CLASS="quote">yeah, i never REALLY broke mine in. I just didn't drive it hard or let it see boost for about 300 miles... but then again it only lasted 3000 miles, Thanks act </TD></TR></TABLE>
lol, hey same here...it only lasted me a good 4k miles!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">if its not organic you dont need to break it in</TD></TR></TABLE>
Thats correct. Puck style disks wont glaze over like organic or kevlar disks can.
(unless exposed to oil). A few slips is all they need to be broken in. They will
just squeal for a little while sometimes while they are wearing in,
expecially if your pressure plate or flywheel arent perfectly flat.
Re: do i need to break-in a 6puck clutch ?? (rioninja)
the reason you break in discs is to heat treat the springs also, and since you're using an unsprung disc no warm them up before use as a break in
Hahaha, i am still trying to get used to the lovely chattering when i try to slip my 4 puck ceramic sprung hub, I still cringe every time...lol
Brett
Brett
Re: do i need to break-in a 6puck clutch ?? (TurboR1391)
just drive normal for about 500 miles, then beat the **** out of it from there on out.
KYle
KYle
harrykong
08-26-2006 07:14 AM
ActiveAero
01-07-2003 04:25 AM
