need info on OBD2 to OBD1
Old Dec 12, 2002 | 09:52 AM
hicamjunkie's Avatar
Default need info on OBD2 to OBD1
for a 99 gsr, to go to OBD1 do you need to change the t-body and/ or the distibutor also?
Old Dec 12, 2002 | 10:10 AM
kenji's Avatar
Default Re: need info on OBD2 to OBD1 (cstew)
You don't need to change the TB nor the distributor.
If you need an OBD2 to OBD1 ECU conversion harness I have some for sale. My email is listed below.
-kenji
Old Dec 12, 2002 | 10:16 AM
YumVTEC's Avatar
yes, kenji is correct. i run a p28 ecu in my 99 EK with 2000 b18c5 and everything on my motor is stock obd2.
Old Dec 12, 2002 | 10:31 AM
Default Re: need info on OBD2 to OBD1 (kenji)
thanks, how much for the harness and a p28 ecu with a chip that will work for all the bolt on but still a stock head and cams?
BoltonGSR
Jun 13, 2008 08:49 PM
egbaby
Mar 1, 2008 06:52 AM
SoyMilk
May 27, 2007 04:19 PM
shawnc21
Jan 9, 2003 11:21 AM
Type RS
Nov 18, 2002 10:09 PM
