engine shaking car
Old Dec 12, 2002 | 09:29 AM
pennies_hatchie's Avatar
Default engine shaking car
i have a 94 si eg with a b16a sir2 with i/e/h in it. we put all the stock sir2 mounts on the engine, but i dont know why it shakes so badly when the car is not moving. when you pop the hood, the engine is shaking (not a lot) but you can tell because the oil checker thing is shaking. but once you sit inside, you can tell that the car is shaking because the stearing wheel is shaking, sometimes the doors shakes, the materials in the glove carmpartment shakes as well. and its annoying as hell, but it only happens when you're not running the motor. once you start reving on it or you drive it, it doesnt shake anymore, but lets say you were at a stop sign, itll start shaking again. the cold weather is not a factor because it has always shaked like that. just want to know your opinions to what might be causing the problem. thanks
Old Dec 12, 2002 | 09:47 AM
advanracing62's Avatar
Default Re: engine shaking car (pennies_hatchie)
are you running urathane inserts/mounts?
Old Dec 12, 2002 | 12:06 PM
allmotorEG-SI's Avatar
Default Re: engine shaking car (advanracing62)
On my old crx it did that. It was all stock too. It was because the idle was 150rpm lower than it should be.
Old Dec 12, 2002 | 12:51 PM
metal-x's Avatar
Default Re: engine shaking car (gixxerdemon)
I had similar problems on my integra shacking and it felt like the car wanted to stall it turned out the to be the alternator belt was lose....
Old Dec 14, 2002 | 06:30 AM
Default Re: engine shaking car (metal-x)
well the idle is between the 0-1 and it idles pretty good, the engine doesnt sound like its going to die or anything. it's just that there's that terrible shaking when it's still, but once you're driving it, it runs perfect, and when its still again, it starts to shake again. i used regular mounts and no inserts. i checked the belts, and they're all on tight. anyone else got any ideas?
Old Dec 14, 2002 | 07:00 AM
slvrcivic97's Avatar
I have this same problem too
Old Dec 14, 2002 | 08:28 AM
hondaeg5's Avatar
Default Re: engine shaking car (slvrcivic97)
i also have that problem,but i have the es mount inserts so i thought that was the cause. i also have a lightened flywheel which also may contribute to a rougher than normal idle. now that you bring it up im worried
Old Dec 15, 2002 | 09:48 AM
Default Re: engine shaking car (hondaeg5)
yeah, i still have that problem, the idle sits at about 800-900 rpm and the stearing wheel shakes like crazy when im still. when the hood is open, you can see the engine shaking a little only, its not shaking crazily or anything, it shakes only a little, but what i dont understand is why is my stearing wheel and my glove compartment shaking as well. when we did the swap, the mounts was set in perfectly, im not sure why, anyone else have any input to this?
Old Dec 15, 2002 | 10:21 AM
Goldfingiz's Avatar
My old CRX did it, and it turns out it needed new mounts. Check to see if they're loose.
Goldfingiz
Old Dec 15, 2002 | 02:27 PM
LowTEC SaiMike's Avatar
Well sometimes at rough idle is just because its at cold starts
Old Dec 29, 2002 | 04:46 PM
Grocery Getter's Avatar
Default Re: engine shaking car (BomBoi)
are you a girl, ive known girls to over react at times, but check your rear mount, see if its cracked, it might be bad causing it shake the cross member just enough to vibrate the firewall to cause the glove box and steering to rattle.
-tim
Old Dec 30, 2002 | 09:18 PM
turbo_civic's Avatar
check your distributor/plug wires/timing, and plugs, make sure all your spark plugs work fine, and they are all getting a spark, my d16a was shaking and i replaced the plugs and wires and set the timing correctly by unscrewing and adjusting the distributor and the shaking has sopped.
Old Dec 30, 2002 | 10:45 PM
gvillehnut's Avatar
My car has alot of the same vibration, mostly when its cold but once it warms up and idles correctly it dies down some. But there is still vibration there even when idling right, but i also have a very light flywheel.
lil kid
Honda Civic (2001 - 2005)
Jul 22, 2008 02:11 AM
meno19
14
Aug 2, 2006 03:03 AM
turbotime
10
Sep 26, 2005 11:21 PM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
Roadrnnr
Sep 5, 2001 05:19 PM
