Upgrade to Hyperground wires?
Old Dec 11, 2002 | 07:14 PM
Blaze45's Avatar
Brrraaaap!
Default Upgrade to Hyperground wires?
Import tunner show'd the dyno w/ a 5 hp increase. Do these really work?
Blaze
Old Dec 12, 2002 | 07:08 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Upgrade to Hyperground wires? (Blaze45)
anyone?
Old Dec 12, 2002 | 07:21 PM
texan's Avatar
No. A capacitor placed inline with the setup is not a contributor to better spark plug firing or anything else. And I don't trust Import Tuner's dyno methods at all, they release very little specific information about testing procedures. Take Nology wires for instance (exact same principle), they were popping up all over the magazines and showing good gains. Why? Because they recommended using only BERU silver tipped spark plugs (as though that makes any difference either) with their wires. So the magazine boys through the brand new wires and plugs in, and viola, a bit more power. Hint: do the same thing but with stock replacements on any motor. The same thing will occur. Brand new spark plugs always seem to slightly elevate dyno numbers.
Old Dec 12, 2002 | 07:38 PM
RaceTilIDie's Avatar
Default Re: Upgrade to Hyperground wires? (texan)
So will an oil change.
Old Dec 12, 2002 | 07:49 PM
Kamin's Avatar
Default Re: Upgrade to Hyperground wires? (RaceTilIDie)
waste of money...
i cant wait till the stunnas start wandering in seeing threads like this and saying
"i have them in my civic it made a huge diffrence"
Old Dec 12, 2002 | 08:39 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Upgrade to Hyperground wires? (Kamin)
thanks
Old Feb 17, 2003 | 07:37 PM
superls92's Avatar
does anyone actually own the hyper ground wires, i've heard nothing but good things about them??
Old Feb 17, 2003 | 08:10 PM
drvfast's Avatar
waste of money
Old Feb 17, 2003 | 11:54 PM
gumbii's Avatar
Default Re: Upgrade to Hyperground wires? (drvfast)
are you talking about the grounding kits.... for the block and tranny and stuff.... they dont make a difference.... i got the HKS ones..... i had to get them.... after my fourth engine swap.... my stock grounds and power cables were looking all bent and chewed up...... paid 150 bucks...... they look real nice...... but its a different system.... the one they have on import tuner are the ones from SunPro... and those are linked up at the end of each point.... like a conect-the-dots...... the HKS ones are thicker and run directly to each ground and power point..... ill try to have a pic in another thread soon..... to drunk...
Old Feb 18, 2003 | 12:34 AM
mey_xanng's Avatar
Default Re: Upgrade to Hyperground wires? (gumbii)
I own them
and I can definately say that it starts easier, and revs smoother
but actual whp gain I don't know
It took only 1 hour to install
Old Feb 18, 2003 | 08:08 AM
advanracing62's Avatar
Default Re: Upgrade to Hyperground wires? (mey_xanng)
I own them
but you're also a supraricer!!! Glad to hear you got everything hooked up!
Old Feb 18, 2003 | 02:10 PM
mey_xanng's Avatar
Default Re: Upgrade to Hyperground wires? (advanracing62)
heh it takes one to know one
btw what do you think of the new DMR logo?
[Modified by mey_xanng, 11:14 PM 2/18/2003]
Old Feb 18, 2003 | 02:27 PM
black-hatch's Avatar
i think there bs y waste ur money just get some good old msd wires or stock ones they work just as good
Old Feb 18, 2003 | 03:12 PM
[HrZn]4life's Avatar
Default Re: Upgrade to Hyperground wires? (black-hatch)
I have the hypergrounds. Not a waste of money but since you guys are so negative I won't bother explaining or show dyno results.
Old Feb 18, 2003 | 03:53 PM
obd2gsr's Avatar
you can run a car, same mods, same settings, 2-3 times within an hour and get up to 5 hp change. depends on too many factors. they sure are pretty, though.
Old Feb 18, 2003 | 04:41 PM
gen2teg91's Avatar
for only $100. not only a slight increase in horse power, increased throttle response, better gas miliage (12% better), starting better, and when you turn your CD player way up, the face will not blink, your headlights do not get brighter when you rev you engine. i think its worth it.
Old Feb 18, 2003 | 05:02 PM
MugenPoweredLude's Avatar
Default Re: Upgrade to Hyperground wires? (gen2teg91)
well according to dynos those wires only give benefit to cars with more than just basic bolt-ons such as turbo....12hp gain on one car...it was turbo....hey if you have 150 bucks to spend give it a shot....they cant hurt
Old Feb 19, 2003 | 07:59 AM
gen2teg91's Avatar
not even $150 go to http://www.sunautomobile.com/ my 91 integra will beat all of u ...i am gods gift to acura..suck my *****
suck my *****
Old Feb 19, 2003 | 10:01 AM
Mr.Saturn's Avatar
Certain cars have more benefits than others. It WILL always help your car start and rev smoother but the power gains are not why you would want to buy this.
Take for example a Civic compared to a 93 RX-7. The Civic (who cares what year) has a great stock ground system that holds up for years, and if replaced doesn't need to be upgraded. By adding bigger wires and more ground points it will start smoother but you will probably gain 1 whp tops.
A 93 RX-7 on the other hand had a decent ground system but it wore quickly over time. By replacing the ground system on this car, you will see a smoother start (hard to notice on rotary though) but you will also see some horsepower recovered. The reason I say it that way is it is like a tune-up, you aren't gaining any power over stock, but restoring it through maintenance. And just for the people who need numbers, I've seen about 10 whp restored on the RX-7 just with this slightly uncommen maintenance job.
Hope this helps! I'd recommend buying some 8 or 4 ga wire and just making your own grounds, probably cheaper!
Old Feb 19, 2003 | 10:04 AM
Mr.Saturn's Avatar
This is something totally different but from what I have pieced togather, these parts are similar to advancing the timing. I assume this is why you are warned by both turbo manufacturers and Nology not to run them on forced induction. Could also be the higher heat generated by them, I'm not sure.
Old Feb 19, 2003 | 01:21 PM
qtiger's Avatar
My Hyperground wires make me a cup of coffee in the morning too.
Extreez
Oct 17, 2006 10:49 PM
staticCRX
20
Mar 13, 2006 02:47 PM
Audipwr1
Apr 16, 2002 04:45 AM
SilverIntegra
Apr 2, 2002 08:32 AM
crookedletterd
Jul 29, 2001 08:40 PM
