Is this true, or BS?
Old Dec 11, 2002 | 05:34 PM
cr-x si's Avatar
Default Is this true, or BS?
I got my new Centerfoce clutch from NOPI the other day. And inside it had a note attached to it that said "With centerforce clutches you must to use a OEM flywheel."
Are they just trying to sell my a flywheel or is this true? I am thinking it is just BS but i thought i would ask you guys.
Old Dec 11, 2002 | 05:40 PM
ViperRedCRX's Avatar
Default Re: Is this true, or BS? (cr-x si)
not true, i was running a cf clutch with a zex ul flywheel
Old Dec 11, 2002 | 05:42 PM
crx(gator)'s Avatar
how are they trying to sell you a flywheel btw...oem is in your car right now, honda is oem...if it said "you cannot use an oem flywheel with this clutch" then maybe you can say they are trying to make more money off of you...
Old Dec 11, 2002 | 05:53 PM
cr-x si's Avatar
Default Re: Is this true, or BS? (crxgator)
o i am stipid, forgive me
Old Dec 11, 2002 | 07:15 PM
Ef Whore's Avatar
complete boosheet
Old Dec 11, 2002 | 10:45 PM
Aron Parsons's Avatar
Default Re: Is this true, or BS? (Ef *****)
OEM is Original Equipment Manufacturer. this is likely stated so they aren't held liable in some way, but many people use non-OEM flywheels with non-OEM clutches, and everythings good. so it's BS to cover their asses.
Old Dec 11, 2002 | 10:52 PM
REX VT's Avatar
Raceclutches can damage an aluminium flywheel, so probably the note is to "cover their asses"
Old Dec 11, 2002 | 11:15 PM
Urban Business
Guest
Posts: n/a
Default Re: Is this true, or BS? (REX VT)
yeppers. however the good ones have a steel engagement area bolted onto the aluminum surface. unorthodox makes really super good light flywheels for us. 8lbs baby
Old Dec 11, 2002 | 11:40 PM
wannab20hatch's Avatar
on the centerforce clutch i installed they said to use a resurfaced oem flywheel if not an aftermarket
DC2-ProdUcTiOnS
May 9, 2009 06:57 PM
fullthrottleking
Aug 1, 2008 08:47 PM
93sivtec
Apr 22, 2007 08:57 AM
cw98typer
Mar 17, 2003 07:53 PM
Zeus Zore
20
Sep 13, 2002 08:05 PM
