Anyone know of any shops located close to northern NJ who install JRSC or fix my prob?
cause i cant find the prob i have to have someone fix it
why don't you post the problem...with the help of this board you might be able to fix it yourself and save $
I don't know of any reputable shops...rpm or drt in ny though
Maybe you need to step back for a day and let it sit. Give your brain a rest. This is what I did when I could not figure out what was wrong with my car. Do you not have any buddies that can look at it?
Is it the high idle problem?
i looked over all the hoses and cant seem to find the prob and i have had people lookin at it but. so my next step is to take it somewhere and get it fixed
SpeedCraft Seaville, NJ (609)517-5957 John
Bullish Racing 249 Lodi St. Hackensack, NJ 07601 (201)342-0449 George B.
Kaztech 13E Moonachie Rd. Hackensack, NJ 07601 (201)229-0939 George
SPI 2 Industrial Dr. Unit F Cliffwood Beach, NJ 07735 (732)290-2213 Jay
DRT Racing 50-33 73rd Place Woodside, NY 11377 (718)397-8586 Rafael
RPM NYC (no dyno) 217-85 98th Ave. Queens Village, NY 11428 (718)740-3277 Tommy or Chan; They both can hold it down with the best in the country
RIPP Mods (no dyno, no talent) 148 Lynhurst Ave. Staten Island, NY 10305 (718)442-1864 Ross
[Modified by GTI 1.8t, 10:59 PM 12/11/2002]
i tryed the IAC valve and when i disconnect it the car doesnt jump high in revs but stalls out unless i start giving it some gas
Is the throttlebody part of the sc or are you using your oem one? I have never looked at an sc up close so I am not sure.
The fast idle valve will be located under the tb. It has one coolant line going in and one coming out.
The fast idle was the piece giving me probs, but mine isnt sc'd so there could be other culprits. :shrugs: From what I understand, the fast idle valve is designed to let air bypass the throttle plate when the car is cold. There is some sort of spring or diaphram that is temp controled and as the coolant going through it warms up, the fast idle starts closing until it closes all the way at normal operating temperature. For me, the fast idle was wide open internally allowing air to bypass the closed throttle plate big time. On my car, there is two ports just inside the tb, one to the iacv and one to the ficv. I noticed that when I covered the bottem port up (the one going to the ficv) the car would idle normal. Thats how I diagnosed mine. Yours might be slightly different though being that it is newer.
Just a thought.
Do you have a Helms manual?
Just a thought.
95civicSirCoupe
Sep 11, 2006 05:34 PM
95civicSirCoupe
Sep 11, 2006 07:49 AM
