b20 in 88-91 crx
Old Dec 11, 2002 | 10:21 AM
i'M tOo SlOw's Avatar
Default b20 in 88-91 crx
does the b20 drop into a crx? or would i have to do some mods?
Old Dec 11, 2002 | 10:29 AM
EP3_05's Avatar
Default Re: b20 in 88-91 crx (sLoWeStCrX)
Well I am sure somebody is going to get annoyed and tell you to search but I will be nice and help you out. No it will not drop straight in. You will need:
Mount kit
Shift linkage
Cable transmission
OBD0 Pr4 ecu and OBD0 90-91 Integra distributor
90-93 Integra axles and intermediate shaft.
These are the "main" mods you will need to make. There are other things too but using the search function should give you a wealth of info. Hope I helped a little bit.
[Modified by 91civic, 2:30 PM 12/11/2002]
Old Dec 11, 2002 | 11:16 AM
Rob!'s Avatar
Default Re: b20 in 88-91 crx (91civic)
blahhhhhh top right corner SEARCH
Old Dec 11, 2002 | 12:01 PM
EL Vap133's Avatar
you will also need a B16 or older Teg mount for the drivers side to fit on the aftermarket mounts....
Old Dec 11, 2002 | 08:39 PM
ef ect's Avatar
Default Re: b20 in 88-91 crx (Vap133)
if any body needs one of those mounts for under the timing cover I got one PM me if intrested
9.3.S.I.L.U.D.E.
Aug 19, 2009 10:39 AM
widecoupe
Jan 11, 2005 04:33 AM
SIKSI
Dec 31, 2004 04:58 AM
work-in-progrex
May 5, 2003 04:18 PM
1990CrxSi
21
Aug 6, 2002 05:18 AM
