ITR Final Drive
If you are refering to the JDM 4.785 then it is just going to make you gears even tighter... The higher the FD the closer it brings your gears together and vise versa. I really wouldn't add one to your 99 Si because that tranny already has pretty high gears... the FD isn't high it's just the gears are made so... For around the same price I would just look into LSD's Quaife??
Well...just as an FYI, the USDM Integra Type R and your Civic Si both have the same 4.400 final drive.
If you have the B16A2, which I suspect with the SC4 or Y21 tranny, then you also have the same gear ratios as the ITR as well.
The JDM Integra Type R has a 4.785 final drive.
EDIT: Damn JDM, you smote me to it.
[Modified by shamoo, 2:08 PM 12/11/2002]
gsr98vtec
Jan 2, 2002 07:42 PM
