taking fenders off?
I know there are about 4 bolts along the fender, you see them when you pop the hood. Then i think there are a couple behind your corner light, and then some on the inside of the fender well. I never changed one, but this is what I remember seeing while working on my car! Hope this helps!! It shouldn't be too hard!
If you open the door there are 2 there.....1 on top one on the bottom....There 10 or 12mm.....Just be careful not to scratch the car or the door edge.
there should be a total of 9 bolts all 10mm. 3 along the top where the hood closes, 1 in the very bottom, 2 in the door jam and 3 behind the corner light/front bumper. Its not that bad some may have glue over top of them need to scrap off, mine was on the 2 in the door jams. You may have to take the front bumper off to access the 3 behind the corner light, I already had my bumper off so not positive about those 3.
Yeah nice front end.......want to see it if your using it for a daily driver, head lights corners outta real look nice.......seen on and it was a hack job because that front end wouldn't fit flush with you lights, they sit back about 3/4 an inch and look like ****, now for a full drag'er do it.....
on. no more fender problems
