Need help with misaligned door (delsol)
Old Feb 4, 2003 | 01:05 PM
SoloSol's Avatar
Default Need help with misaligned door (delsol)
A few years ago i wasted my drivers door doing something stupid. Well I replaced it witha used one. I didnt think that there was much more to it than rehanging it as it was like 4 bolts if I remember correctly. Since then the dome light will not opperate properly becaust the bottom rear edge is not tight against the seal. I dont know how to adjust this..has anyone had this same problem and could lend me some suggestions.
Old Feb 4, 2003 | 03:31 PM
Propulsion's Avatar
Default Re: Need help with misaligned door (SoloSol)
loosen the 4 bolts, have someone allign the door while you tighten. then close SLOWLY to check for clearance, careful, it might rub your fender
ace8
Sep 18, 2009 08:09 PM
itellyawhat
11
Feb 19, 2005 01:07 PM
acourt
Nov 27, 2004 05:38 PM
tha Big EZ
Dec 4, 2003 10:47 AM
andrewasf77
Feb 9, 2003 08:41 PM
