neccesary to O-ring the sleeves ?
Old Dec 10, 2002 | 10:14 PM
Danger's Avatar
Default neccesary to O-ring the sleeves ?
i am putting together a fully built ITR motor for turbo . i had the block sleeved by GE but it wasnt o-ringed . is it neccesary ? i plan on boosting around 25lbs , would not having it o-ringed cause me to blow a headgasket ? any help would be appreciated . thanks
Old Dec 10, 2002 | 10:25 PM
Speedworks801's Avatar
Default Re: neccesary to O-ring the sleeves ? (jonny5)
It's a good idea, however there are many people running those boost levels without any problems on stock headgaskets.
Good luck!
Old Dec 10, 2002 | 10:35 PM
InfamousRS's Avatar
Default Re: neccesary to O-ring the sleeves ? (Speedworks801)
Can you still use a OEM head gasket with a O-ringed block?
Old Dec 10, 2002 | 10:38 PM
*Boostwerks*'s Avatar
Default Re: neccesary to O-ring the sleeves ? (InfamousRS)
Yes, and this setup is even recomended.
Old Dec 11, 2002 | 12:58 PM
Danger's Avatar
Default Re: neccesary to O-ring the sleeves ? (Bryson)
thanks
Old Dec 11, 2002 | 02:06 PM
highbrid's Avatar
just a warning though that orings can be a bit difficult to get to seal, but when they do seal they are great.
IntegraGSR(-1)
Feb 13, 2006 10:37 AM
Turbocivic94
Apr 25, 2005 06:21 PM
RICE POLICE SIP
Apr 22, 2004 12:41 PM
01ITR#700
Nov 26, 2002 11:31 AM
Ri5e
Sep 7, 2002 08:20 AM
