255lph in-tank and stock injectors can I pass cali emissions...
Old Dec 10, 2002 | 08:37 PM
D16A6Turbo's Avatar
Default 255lph in-tank and stock injectors can I pass cali emissions...
Whenever I go for a smog test, I always pull the turbo system out along w/ all the fuel components...now that I'm going to add a 255lph intank, I was hoping I could leave it in when I test...As you all know dropping the tank is always a PITA...everything else will return to stock...injectors, FPR and ECU...
Old Dec 10, 2002 | 08:57 PM
turbod16y8's Avatar
Default Re: 255lph in-tank and stock injectors can I pass cali emissions... (D16A6Turbo)
you wont pass. you'll be running wayy too rich.
Old Dec 10, 2002 | 09:55 PM
DeepSi's Avatar
Default Re: 255lph in-tank and stock injectors can I pass cali emissions... (turbod16y8)
you dont have to drop the tank to install the fuel pump. just raise the seats and pull the pump out. there are a few more things to do, but you get the point.
Old Dec 10, 2002 | 10:10 PM
D16A6Turbo's Avatar
Default Re: 255lph in-tank and stock injectors can I pass cali emissions... (DeepSi)
Sorry, not in a 91 civic...
Old Dec 10, 2002 | 10:21 PM
sporkcrx's Avatar
wouldn't he be able to just lower the fuel pressure?
I have a walbro in my crx, i know your pain...who knows what i'll do when it comes emission time.
Old Dec 11, 2002 | 12:13 AM
racecarpete's Avatar
Default Re: 255lph in-tank and stock injectors can I pass cali emissions... (sporkcrx)
if you had a vafc, couldn't you really lean the car out before inspection to where you are almost lean?
Old Dec 11, 2002 | 04:48 AM
fastludeh22's Avatar
Default Re: 255lph in-tank and stock injectors can I pass cali emissions... (SilverCivic2k)
lower the fuel psi if it is a prob., or couldnt you use smaller then stock injectors?
or ive heard of people unhooking 1 sparkplug and 1 fuel injector. if you dont pass emissions on 3 cylinders, there is no hope.
kirby_lys
Apr 8, 2010 06:12 AM
civic.com.hk
Feb 23, 2004 11:38 PM
minorthreat
Mar 23, 2003 11:35 AM
