quick question about fpr
Old Feb 23, 2004 | 09:39 PM
civic.com.hk's Avatar
Default quick question about fpr
i m sorry but i really dont have much time to do search. i kind of looked at a couple pages but i did not really find anything, so i have to ask u guys:
i have a greddy turbo kit in my 2000 civic ex (d16y8). since the kit was used, it did not come with the blue box and large fuel injectors. for fuel upgrade i only have a aem fuel rail and a bbk 225 fuel pump. my car is running too rich now and i need to turn down the fuel pressure. i will have to bring my car to the smog. i have a b&m fuel gauge and a autometer fuel pressure gauge(reading 32 psi right now, with fuel pump off and 34 with fuel pump on). my question is:
which fuel pressure regulator should i buy (tight budget) and what psi should i set it to so i can ensure to pass smog test.
thank you thank you thank you!!!!
smog test is due this week, please let me know soon!
Old Feb 23, 2004 | 09:45 PM
ndogg's Avatar
Default Re: quick question about fpr (civic.com.hk)
so you are running a turbo with stock injectors and a fuel pump and you think you need to turn down the pressure? dude... i don't know what to say.
Old Feb 23, 2004 | 09:52 PM
Default Re: quick question about fpr (ndogg)
by looking at the carbon deposits on my exhaust tip and on all 4 spark plugs, my car is running rich. and it also shows on my air/fuel ratio gauge.
Old Feb 23, 2004 | 09:59 PM
Alstare's Avatar
heh...
You might wanna check into that and make sure...
Old Feb 23, 2004 | 10:12 PM
Default Re: quick question about fpr (Alstare)
check into what?
Old Feb 23, 2004 | 10:37 PM
ATS*Mark's Avatar
OG triple OG
wow dood , wow....your running NO fuel management at all???? and your running rich? im running emanage and my fpr is at 42 psi , and at 8 lbs i lean to 14.5:1 a/f ratio , which is lean.
Old Feb 23, 2004 | 10:40 PM
Default Re: quick question about fpr (Hella_JDM)
so will the b&m fpr be fine? will it fit on the aem fuel rail?
Old Feb 23, 2004 | 10:42 PM
but isnt the b&m a fuel pressure raiser? so is aem fpr my only choice?
Old Feb 23, 2004 | 10:46 PM
ATS*Mark's Avatar
OG triple OG
dood , you dont seem to be getting it.....you dont want to lower your fuel pressure on a FI setup
Old Feb 23, 2004 | 10:50 PM
i know that, i know i should keep it richer than NA if i boost it, but the point is that i want to pass the smog test right now and i know that i will not pass it if my car is running this rich.
Old Feb 23, 2004 | 11:00 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.com.hk &raquo;</TD></TR><TR><TD CLASS="quote">i know that, i know i should keep it richer than NA if i boost it, but the point is that i want to pass the smog test right now and i know that i will not pass it if my car is running this rich.</TD></TR></TABLE>
You're car won't be running if you go any leaner.
Did you get it that time?
Old Feb 23, 2004 | 11:04 PM
ndogg's Avatar
Default Re: quick question about fpr (nd_styles)
do you have an AF ratio gauge? autometer or any other narrowband don't count. unless some magical honda genie is giving you extra fuel... you are NOT running rich. and need to get your car tuned asap before driving it anywhere, let alone to the smog station.
Old Feb 23, 2004 | 11:05 PM
sorry, i really dont get it. all i want is just lower the pressure a bit when i take it to the smog, then raise it back to what i have right now. they will measure the smog at 3000 rpm right, and they will not even engage the turbo.
Old Feb 23, 2004 | 11:19 PM
ATS*Mark's Avatar
OG triple OG
ok check this out . the fpr is stock the injectors are stock , i dont see how a fuel pump is gonna change anything but pump more fuel to those parts which will restrict it , so your fine , it will pass smog , but what turbo kit you runnin , because you should be more worried about having a turbo kit thats not carb legal in ur ****
Old Feb 23, 2004 | 11:31 PM
oh, according to this http://arb.ca.gov/msprog/after...7.pdf my kit is ok (greddy kit for a 2000 civic ex). i went to a couple smog shop already and ask them if it's ok, they called the referenree and made sure that it was ok.
but if u say that my car will pass smog and it's not too rich, then why there is so many carbon deposits on the exhaust tip? i know that there shouldnt be anything to cause it to run rich, what do u think the problem is?
Old Feb 23, 2004 | 11:38 PM
ATS*Mark's Avatar
OG triple OG
thats just forced induction man.....mine has a black ring around the exhaust tip , and runs leaner than it should
cashshoes
Oct 19, 2006 12:09 PM
wpgcivic
May 2, 2006 02:32 PM
TurboB18C1
Aug 30, 2004 01:37 PM
G3NR8
Jun 18, 2004 09:09 AM
Simple
Jun 20, 2003 07:33 AM
