GSR cluster into CRX
thanks, one more question.
How do i know what pin is wich? Anyone know a site showing a diagram of the plugs?
You get the vss out of y1 trannys, at least thats were i got mine.
here is all the wiring i used to do mine...
1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Green/Red-Door Light
8)Red-Dash-Dash Lights
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11)red/Blue-High beam
12)Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Feul Gauge
4)Not Used
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
2)Geen/Orange-Check engine
3)Yellow/Orange-Oil Light
4)Not Used
5)White/blue-Volts
6)not used
7)Yellow/green-Water Temp.
8)black-ground
9)Red/Blue- cruise(not used unless you have it)
10)Yellow-12vPower
11)Not Used
12)Not Used
13)Not Used
16 Pin connecter
1)Green/red- E brake
2)red/Green-High Beam
3)Green/Yellow-Right Turn signal
4)Green/Blue Left turn signal
5)not Used
6)black/yellow-12vPower
7)Red/Black-Power
8)Red-12vpower
9)blue/Red-ABS(not used unless you have it)
10)green-Trunk Light
11)Orange-VSS
12)not used
13)Blue/White-Low Feul(not used unless you have it)
14)Yellow/white-Feul Gauge
15)Green/Red-door
16)red/blue-seat belt
hope this helps worked perfect for me just match the wires up.
1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
6)Green/Red-E brake
8 Pin connector:
2)Yellow-12v Power
4)Not Used
6)Not used
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
4)Not Used
5)White/blue-Volts
6)not used
8)black-ground
10)Yellow-12vPower
11)Not Used
12)Not Used
13)Not Used
16 Pin connecter
5)not Used
7)Red/Black-Power
8)Red-12vpower
11)Orange-VSS
12)not used
15)Green/Red-door
New User
the VSS i need Electric? Cause the ones in the cable trannys are just a cable... i need the actual one with the wire so i can run it to the tach right?
team2dcrx
Aug 28, 2008 11:39 AM
ALLMOTOR CRX
Feb 13, 2007 05:07 PM
GSRCRXsi
18
Nov 13, 2004 01:08 AM
