Low brake pedal
Old Dec 10, 2002 | 08:47 AM
hmonglonertim's Avatar
Default Low brake pedal
This is on a 97 civic hb. I bled the brakes at all 4 wheels. Passenger rear, then driver front, then driver rear, then passenger front. It was still low so I replaced the master cylinder. Before installing the master cylinder I bench bled the master cylinder. I then installed the master cylinder and gravity bled all 4 one at a time then bled it normally but the brake is still low. No brake fluid present on push rod in the booster. Tried bleeding the master cylinder while still on the vechicle and when I open the lines to the master cylinder while the brake pedal is depressed, no fluid comes out. What should I do/check for? Do I have to adjust that pushrod any?
5rivers
Oct 10, 2015 06:44 AM
JJexpress
Apr 4, 2009 07:22 PM
mattbatson
Oct 23, 2008 07:30 PM
integra123
Aug 8, 2006 05:52 PM
KenTegra
Apr 7, 2002 01:57 AM
