Blown engine at track day! What now?
Old Dec 10, 2002 | 02:22 AM
EE8's Avatar
EE8
Default Blown engine at track day! What now?
Well not exactly on the track but in the paddock warming up.
So last sunday I went to a track day trying to have a little fun. 15 minutes before my session I turned on the car for two or three minutes and then drove slowly off to warm up the tires. After a few turns around the paddock area oiltemp was OK water temp was OK and I pushed a little harder, engaged vtec and around 6500rpm and 7000rpm a heard a strange noise and saw a big cloud of white smoke coming of the rear of my car. It then stalled and I knew something bad happened. The engine block cracked open at the juncture with the oil pan right below the AC mount.
A few months ago I had to replace the rod bearings due to oil starvation after a broken oil-radiator, seems like the guy who did the job didnīt quite cut it although he is a Honda mechanic. The strange thing is it was running fine for almost 6000km, no noises no nothing. Very strange.
Now what do you guys think happened?
What are my options now, what should I do?
Old Dec 10, 2002 | 03:19 AM
97hb's Avatar
Default Re: Blown engine at track day! What now? (EE8)
Oil pump could have gone out causing oil starvation, leading to the hole in the block. Could also be that it wasn't built right.
Old Dec 10, 2002 | 04:48 AM
sneakychaos's Avatar
Default Re: Blown engine at track day! What now? (97hb)
You guys in Lisbon have no luck with ITR's.
Old Dec 10, 2002 | 05:01 AM
DutchITR1689's Avatar
Default Re: Blown engine at track day! What now? (sneakychaos)
LOL! Darkteg is the only one without engine problems, right? And soon he will be able to build his own B18C6 with his new Shop Manual.....
Old Dec 10, 2002 | 06:31 AM
austrian type-R's Avatar
Default Re: Blown engine at track day! What now? (DutchITR1689)
that sux!!!! You have any pics of the engine?!
Old Dec 10, 2002 | 07:39 AM
Darkteg's Avatar
New User
You guys in Lisbon have no luck with ITR's. LOL! Darkteg is the only one without engine problems, right? And soon he will be able to build his own B18C6 with his new Shop Manual.....
well actually no engine problems and counting 171.000km, but some body damage 4 months ago...
the shop manual was also for EE8 but no one was expecting what happened...
Old Dec 10, 2002 | 08:09 AM
Default Re: Blown engine at track day! What now? (Darkteg)
171.000 km (107k miles)?!?! Wow, that's a lot for an ITR....
Old Dec 10, 2002 | 08:27 AM
importfreak02's Avatar
That is a ton of miles. Dange park it for a couple months man.
Old Dec 10, 2002 | 11:09 AM
pinota's Avatar
Default Re: Blown engine at track day! What now? (importfreak02)
Man, that sucks !!!
Iīve got a B18C block weeks ago to put my ITR stock, i can help you out on getting another one.
Pinota
Old Dec 11, 2002 | 12:01 AM
EE8's Avatar
EE8
Default Re: Blown engine at track day! What now? (pinota)
Well I guess it wasnīt build right cause the car only has 17.000km and I donīt believe it was the oil pump.
Old Dec 11, 2002 | 06:27 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
bad torque specs
Old Dec 11, 2002 | 07:43 AM
EE8's Avatar
EE8
Default Re: Blown engine at track day! What now? (MUTANT X)
most likley.
Now I just feel like fu... ..ing up the guy who did the job.
Old Dec 11, 2002 | 08:25 AM
Darkteg's Avatar
New User
open up, look for the broken part(s) and take conclusions.... don't go talk with the mechanic without knowing exactly what happened.. just my 2 cents Mike.
Kevin
Nov 9, 2010 06:44 PM
maxogsr
Jun 2, 2010 02:27 AM
SFWD tC
May 6, 2005 07:08 AM
RRRex
Oct 13, 2003 07:05 AM
Warren
17
Feb 26, 2002 11:57 AM
