Piston suggestion
Ok, here's my dilemma, I am torn between two pathways and just don't know what to do. I either want to P&P my stock head and get pistons (and whatever else is necessary) or no P&P and build the head/block up.
So basically my question is what is the more reasonable solution for everyday driving, money is a slight issue (not interested in paying tons of cash, but I have a little stashed away for a rainy day aka car parts).
Currently I have the mods in my sig, but any input on which pistons and compression to run keeping in mind that I will be running on 91 octane (gotta love Cali for that
) for each of the two pathways as previously laid out. Thanks.
CTR pistons. they'll bump you up to bout 11.75:1 and give you a nice jump in power. PnP on the head is your call... won't see as much power as you'd like to from the money you spend on it - but it will yield some nice results.
No is right , the pistons will have the biggest effect, And will work well with the JUN3's. Spend the rest of your money on cam gears and the dyno.
[Modified by CRVRX, 1:20 PM 12/10/2002]
If you want pistons higher than CTR pistons, you'll either have to order custom ones from JE, SRP, Arias, Manley, Endyn, Wiesco, etc... and you might have the piston slap problem that I have... I forget if you've heard my car yet! Sounds like a diesel needing a tune-up on cold mornings.
If you're gonna get headwork done anyhow, get the CTR pistons and have the head machinist shave off a few thou off the deck to bump up compression a bit more... but since you're gonna be in Cali for a little while longer, I'd advise against that...
What about pistons higher in compression than the CTR pistons? Are they very streetable?
You can also consider getting a new thinner head gasket, like the Mugen or Spoon 1 layers, and bumping you upto about 12:1 compression. The pros of the CTR pistons are they are a good cheap alternative to help raise compression. There is no (usually, or so I've heard of) piston slap. With forged pistons, you'd get a lighter piston with is good to have less weight on the rotating mass, however it will usually cost you more, and you will have piston slap during colder days / cold starts.
One other thing to consider is OEM internals, (IE CTR Pistons) can take more of a beating them their forged counterparts. In beating, I mean handle detonation better and are less likely to break on you. Yesh, thats just my opinion, and yesh, its very vague.
How exactly do the CAST CTR pistons handle detonation better than forged pistons?
Casting makes them more brittle if I'm not mistaken and forged packs (more) denser material into a certain shape (pistons)
Cast wheels are more prone to breaking than forged wheels no? Not exactly the best comparison....but somewhere along those lines.....
One other thing to consider is OEM internals, (IE CTR Pistons) can take more of a beating them their forged counterparts. In beating, I mean handle detonation better and are less likely to break on you. Yesh, thats just my opinion, and yesh, its very vague. <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emsmilep.gif" BORDER="0">
spend a few extra bucks while the motor is cracked open and do it right. Go forged, you`ll thanks us later.
Ryan
Ryan
Austin
That's about right...oh and a B18C5 block with ctr pistons and a mugen head gasket yields ~12.5:1.
Austin
Austin
Are we talking about the standard or oversized CTR pistons.
Austin
They're almost the same regardless, but I was speaking about oversized, because that's all that we should be using after a rebuild...at least in my opinion.
[Modified by Yellow3TypeR, 10:57 AM 12/11/2002]
i would get the head done first then tune it, and see how you like it.
building the block will cost the same as a full rebuild on the block since you should
replace all the bearings and seals while you are down there anyway.
ctr pistons alone are good for over 12:1 compression whoever says otehrwise needs
to check their math.
i like sgts idea
also remember if you rebuild the bottom end, it will cost way more, and you wont have your car for as long.
what is your goal hp?
if you rebuild with ctr pistons, new bearings andother fun stuff. it will cost in the 1-1.6k range. depending upon labor.
your car will not be in usage for a while too.
just get the head done. turnaround is very fast. and once you rebuild your bottom end. your head will flow so that it wont be the weak link when you get a better bottom end.
just remember to K.I.S.S.
i would look into getting forged internals and spending more to have your block sleeved to 2.0. lotsa tq. but you are looking at around .5k for getting it re-sleeved
I don't really have a specific hp in mind. Labor is cheap for me, my cousin owns a shop so basically I pay him nothing but for the parts. The only concern is reliability and the wear on my car, I want to keep the R for a while, so I don't want anything that will blow up on me.
PLATANOLOCO
Oct 30, 2011 07:26 AM
